ABS Going in and Out?
amaldhiz
Hello All,
A little background on the problem. Had the brakes done all the way around 7 months ago, Rotors and Pads. Since then there have been around 9k miles put on it, so not a lot at all.
A couple weeks ago my wife slid in the snow (side ways just a bit) but it was fine it's happened a 1000 times since I've owned it. Now the ABS and Traction lights show up and everything is fine, it brakes like normal and all is right in the world. Light goes off however and the brakes lock up and I hear that "BBBBBPPPP" Noise from the ABS and it grinds and pulses for no reason, snow, wet, dry it does this. Its been super cold here in Ohio and snowy to boot, but I've never had this issue in the last 7 years even when I forgot to replace my pads for quite some time.
TL;DR Newer Brakes, ABS/Trac lights come on, brakes are fine, light goes away they pulse and grind like crazy for no reason.
What in the world is wrong here?
  • 4 weeks later...
