cclaxton Posted March 26, 2015 Report Share Posted March 26, 2015 I know the 2015 Ford Edge has the option for automatic highbeams. I had this on my Cadillac and loved the feature. Is there any way to retrofit a 2014 with the Ford 2015 parts and use Automatic highbeams? Or, any aftermarket kits available? Thanks, Cody Quote Link to comment Share on other sites More sharing options...
omar302 Posted March 26, 2015 Report Share Posted March 26, 2015 There is this, but I don't know if it works fully on the Edge: http://www.mobileye.com/products/mobileye-5-series/ 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted March 26, 2015 Report Share Posted March 26, 2015 Highly doubtful. Since no Edges had auto-dimming the code to do it won't be in the PCM or the controlling module even if you added the sensor. You'd have to go aftermarket if anything. I have that on my 2013 Fusion Titanium and it's probably my favorite feature. Quote Link to comment Share on other sites More sharing options...
cclaxton Posted March 26, 2015 Author Report Share Posted March 26, 2015 The Mobileye would probably work. But I am wondering if I can get the 2015 detector (Is it in the mirror?) and then have it custom-wired into the high beam switch, and install a simple toggle switch to turn it on and off. They did a similar modification to add front parking sensors to my 2014 Edge. There is a toggle switch that turns them on/off. Warranty might be an issue. Cody Quote Link to comment Share on other sites More sharing options...
akirby Posted March 26, 2015 Report Share Posted March 26, 2015 The sensor probably communicates with the SJB to control the lights so the logic to interpret the sensor is in the SJB, not in the "detector" so you can't just install the detector to activate the switch. Quote Link to comment Share on other sites More sharing options...
