terrible sound quality
First off, brand new to the forum and a proud owner of a 2007 edge sel plus as of yesterday. I'm very suprised on how poor the audio quality is. I traded in a 2008 base model dodge charger and the stock sound system (4 speakers) blew this one out of the park.
My edge does not have the factory subwoofer so I imagine it's a 4 speaker setup as well. It does have the navigation head unit. Any updates that I can do aside from throwing a $500 sub box in the back for better lows and mids?
In the past, when I just replace the door speakers, I only get improved trebble. Maybe it's the insides of the doors that don't help with the sound quality? I don't know. Any advice is greatly appreciated.
Have you checked all of the sound settings? Do that first. Replacing the door speakers can help even with mid-bass depending on what you get. Infinity Kappas are popular as are Polk Audio and they're not super expensive. Do that first, then see if you need a separate sub.
Yes, I adjusted the eq settings the best that my head unit would allow (only trebble and base adjustment available). Im suprised that a higher end "ford" headunit is so limited in sound adjusting. Maybe I will try some new speakers like you said. I came across some kicker components. Is there a tweeter hole already available somewhere in the edge?
Not unless you already have the triangles at the top front of the door panel - they hold the tweeter for the component setups. Don't remember if those were available on the 07 Edge. You can easily add them to the A pillar if you want to go components for the front.
What was DSP set to? All seats, driver or rear?
