Error Codes P0060, P0480, P1000
georgetown
I have a 2007 Edge and had a local mechanic swap out my coolant fan. I purchased the fan and he did the labor. I am driving home and the check engine light pops up. Got home and put the scanner on and these are the codes that popped up.
P0060 HO2 HEATER RESISTANCE (BANK 2, SENSOR 2)
P0480 FAN 1 CONTROL CIRCUIT
P1000 OBD SYSTEM READINESS TEST NOT COMPLETE
ANYBODY KNOW WHAT CAN CAUSE ALL OF THESE ALL OF A SUDDEN?
ANY HELP WOULD BE GREATLY APPRECIATED.
Very disjointed codes! Which brand of fan did you have put in? We have already had one report of a TYC fan causing problems.
Most likely the issues are from connectors not making proper contact, or fuses not being fully seated/in the wrong slots, etc. The P1000 can easily cascade from the P0060 code. There shouldn't have been any oxygen sensor involvement in the fan replacement, except possibly the wires getting nicked while the vehicle is on a lift for service, for example.
