2013 sport ground effects
Brian1973
No tape apparently, there are 4 screws in all, and some tabs underneath that need to be unclipped.
  1. Remove the rocker panel moulding front cap.
    • Remove the 2 screws.
    • Remove the front cap.
  2. NOTE: RH shown, LH similar.
    Remove the 2 screws from the rocker panel moulding inside the rear wheelhouse.
  3. Open the front and rear doors.
  4. Release the retainers on the bottom of the rocker panel moulding.
  5. Pull outward to release the rocker panel moulding from the body, starting from the front of the vehicle moving rearward.
  6. To install, reverse the removal procedure.
  • 2 months later...
