Phone switch automatically to A/V IN
roshka82
Hi All,
Appreciate on any advise or assistance. Actually it happened after we separated the battery wires from the system for a short time, 5 min.
So the problem is - when i connect my mobile via bluetooth and then dial any number when i listen to radio or mp3 then the sound of the music increase a bit and i can't hear my opponent via bluetooth nor neither beep of the phone. Then i end the call and the mode on SONY SYNC switch automatically to A/V IN. Any ideas?
Thanks,
Rashad
Try disconnecting the battery for about 10 minutes & see if it helps.
Thanks, actually it happened after when i disconnected the battery for 10 min. The next day after that i can get access to my car because of seems everything was erased from car memory, even car did not recognize it's fob, i tried to open the door with key inside of fob and then insert the fob itself inside of speciaal place for key and they i can turn the engine.
Do you think that it might work if i disconnect it again?
Thanks,
The FOB programming should not reset with a battery disconnect. Something went wrong. I would check all the fuses & also try another battery disconnect, for a longer period than the first time.
I believe it's not the disconnect, rather the reconnect. If your not careful and make full, continuous contact when reconnecting, you might create a spark (or sparking) cwhich allows current to genetate spikes in tbe circuitry. Sometimes spikes cause very high voltages that are capable of causing a breakdown of the IC's. And sometimes it just scrambles memory circuits.
Like OMAR said, try a battery disconnect, wait ten minutes to allow the capacitors to drain and reconnect.
