p0018 and p0021 need help, topic related to previous October one.
colorado
ok, so i did change both my vct selenoid, reinstalled everything, change the oil and started the engine. engine running very rough at idle and got this code( P0018 camshaft position/camshaft correlation bank 2 sensor A)(same message but with P0018(pd) and P0021-P0021(pd) camshaft position timing over advance or system performance (bank2). did put a brand new camshaft sensor in front, r/h side.when for a drive, look like i got power and its running fine but when i came back in the garage, running rough at idle. also can hear some noise in engine that was not there before i change the vct solenoid. also check my solenoid by adding 12 volts power on it, they do works. also disconnected the battery the reset computer. no luck. am i missing something? thanks
