Why do my red led alarm lights not stay on?
Those aren't alarm lights, they're just lights to tell you that the doors are locked. If you want an alarm light, you need to add the optional perimeter security system (FT4Z-19A361-A) with the also optional LED indicator (DM5Z-19D596-A).
I added that to my Edge specifically for the flashing alarm light. I don't care so much about the alarm, but was hoping the light would at least be a bit of a deterrent to someone who might try breaking a window. However the light only blinks about once every 10 seconds and it's only on for about a quarter of a second at a time. You have to know where the light is and wait for it to see if the alarm is armed. I doubt it actually would work as a deterrent.
But why? They don't indicate an alarm being active - they are there just to confirm the action of locking the doors because there are no actual moving lock knobs. I guess Ford figured that anyone wanting to fake an alarm system could do it with readily available aftermarket parts. You can buy red LED lights to mount in the dash that are designed to blink whenever the ignition is off. You can even buy lights that look like the scanner on Knight Rider.
Edited by TheWizard
My battery was dead after being parked for 23 days last June. That was with the alarm system installed. I didn't park it that long before I had the alarm installed, so I'm not actually sure how much of an impact the alarm had, but I'm sure it shortened the life a bit. Actually, I'm not even sure at what point during those 23 days that the battery died.
This was a problem with my last vehicle too, so I've got one of those Li-Ion jump starters that fits nicely in the center console. That's so much easier than looking for someone to give you a boost.
