gwhite Posted November 29, 2018 Report Share Posted November 29, 2018 My new 2018 Ford Edge is my 4th Edge- V6 SLE. I loved my 2015 so much that I bought a 2018 after a short test drive, assuming it would be very similar. After driving it a while (after the test drive and purchase), I noticed that it had "heavier" steering than my 2015. I really liked the "light" steering of my 2015, so I thought it was a " no brainer" buying the new one, which does not have adaptive steering. Much to my my surprise. and without any special Ford reports, I discovered that they have changed the part number of the rack and pinion steering gear beginning in February 2018.. Quite common, I am told, but I have been stonewalled by various Ford dealers as to the reason why. I am particularly sensitive the issue because I basically live in my car. It seems to track better than the previous version, but it takes more effort, especially at lower speeds. Any suggestions or input? 's s Quote Link to comment Share on other sites More sharing options...
Ryanmaasmn Posted November 29, 2018 Report Share Posted November 29, 2018 Sounds like they probably changed the dynamics of the power steering setup... Or maybe check to see if your power steering fluid is lower than it's supposed to be? If I knew more about ECU I would suggest looking into some kind of option for reprogramming something in there. Quote Link to comment Share on other sites More sharing options...
gwhite Posted November 29, 2018 Author Report Share Posted November 29, 2018 I believe they use a "sealed" system so there is no power steering fluid reservoir. I searched all over the internet to see if anyone had the same impression on their 2018, but so far nothing. Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 29, 2018 Report Share Posted November 29, 2018 The 2015+ Edge has electric power assisted steering (EPAS) so no oil is involved. Does your 2018 has the same wheel/tire as the 2015? Also check with the dealer, maybe they can do something. 1 Quote Link to comment Share on other sites More sharing options...
gwhite Posted December 4, 2018 Author Report Share Posted December 4, 2018 Apples to apples, everything between the 2015 and 2018 are exactly the same, so why does the 18 it drive differently. Not worse, I might add, but tighter steering and not as cushy over bumps. Different part number on the struts and steering box, but they often change numbers, I'm told. No one in Service or Parts or Sales has any explanation and Ford did not have any kind of announcement or bulletin. Maybe it's my imagination? s Quote Link to comment Share on other sites More sharing options...
