AntDeek Posted April 8, 2019 Report Share Posted April 8, 2019 Hey friends, Has anyone figured out a way (if any) to get low level outputs from a stock non sync base audio system? For my sub now, I am running with the rear speakers to a line output converter. Thanks! Quote Link to comment Share on other sites More sharing options...
fishx65 Posted April 10, 2019 Report Share Posted April 10, 2019 How does it sound?? I just picked up an amp with high level inputs so I can run a small sub by taping into the rear speaker leads. If you don't mind me asking, where did you tap into the rear speaker wires???? Quote Link to comment Share on other sites More sharing options...
AntDeek Posted April 11, 2019 Author Report Share Posted April 11, 2019 20 hours ago, fishx65 said: How does it sound?? I just picked up an amp with high level inputs so I can run a small sub by taping into the rear speaker leads. If you don't mind me asking, where did you tap into the rear speaker wires???? Sounds great Lots of thump. I tapped in to the rear speakers in the door behind it's factory connectors, using Posi-Taps. Quote Link to comment Share on other sites More sharing options...
