EdgeEh Posted June 27, 2019 Report Share Posted June 27, 2019 The driver side seat belt in my 2018 Edge is currently stuck in fully retracted position. It looks like the lock is engaged and I cannot pull it at all. I tried pulling gently, yanked it a bit, still nothing. Does anyone have any solution for this? My closest dealer is 4km away, so I may be able to just drive without seat belt there but I don't want to risk being pulled over for not wearing seat belt. Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 28, 2019 Report Share Posted June 28, 2019 Try to lower the seat belt shoulder anchor to get it to retract a bit. Another thing to try is a sudden brake from like 5 mph. Quote Link to comment Share on other sites More sharing options...
EdgeEh Posted July 8, 2019 Author Report Share Posted July 8, 2019 Bit of an update. The seatbelt was working again the next morning and it continued to do so for few days. Then it happened again (both times parked outside, hot sunny weather). Luckily I had nothing to do that day, so I had it towed (Ford Roadside assistance) to my local dealership. The service manager ripped open the plastic cover, wiggled the seat belt and he fixed it. It is still getting replaced under warranty though. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 9, 2019 Report Share Posted July 9, 2019 Thanks for the feedback. Now that you mentioned it was sitting outside, my Edge's driver seat-belt seems to be affected if it was heat soaked. Though it does not fully lock, only locks a couple times while trying to buckle up (have to retract it a bit then re-pull). Other than when being heat soaked, it works fine. Quote Link to comment Share on other sites More sharing options...
WillM Posted June 12, 2025 Report Share Posted June 12, 2025 This seems to be an issue because mine does the same thing during hot weather. Im going to try the stopping method and see or perhaps lower it a little. Thanks for sharing. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 27, 2025 Report Share Posted August 27, 2025 Try spraying the machismo at the floor with WD40. Gums up and causes the cam to stick. I got tired of my wife ... requesting .. me to fix it properly and replaced it with a new a$$embly. (And with a 2009 MKX, which are now obsolete, I had to scour every dealer in the country to find one; in my color.) Quote Link to comment Share on other sites More sharing options...
