Edge 2007 Transmission Main Control Body / Solenoid Body Assmeble
Travtrav808
Hello All, I removed the Solenoid and Main Control Valve to replace two sensors.  Seven bearings and a piston slipped out from the main control assembly.  I can't tell where the seven bearings originated from and which direction the piston fits. Is there a diagram available to show this assembly?  Thanks.
