Under engine splash shield push pins
theoldwizard1
The splash shield under the engine must be removed to do an oil change.  It is held in place by either plastic push pins of screws into plastic inserts.  Except for the back 2.  I have not been underneath since the last oil change (7,500 miles ago) but I know one or both are failing and these are different than the others.  They are square and are inserted into a square hole in the frame.
Anyone know where I can find some of these without paying an arm and a leg ?
Edited by theoldwizard1
