2016 3.5 towing. Pls confirm for me...
The weight limit on the 2016 Titanium 3.5 without the Class II package is 1500#. Correct?
Since it doesn't have the class II package it's not 3500?
Even if I put a class II receiver/hitch on it?
Because it still doesn't have sway control?  Which only comes in the package?
How about trans or oil coolers? Are they standard?  In the package?
 Thanks!
4 hours ago, omar302 said:
Without the factory tow package, the 3.5 Edge is rated to 2000 lbs.
The rating will not change even if you put a class II hitch. Sway control is one part, but the tow package usually also has additional cooling capacity like an engine oil cooler.
thank you, sir.
