Dylan2012edge Posted December 29, 2020 Report Share Posted December 29, 2020 Hey how’s it going. I have a 2012 Ford Edge sel. It’s the 3.5 v6 and awd. I’ve been having troubles with the backup camera and I’m curious if anyone had a solution for it. Basically the camera will not work for like a week and I’ll get an error message when In reverse. Then the next week it works fine. But for the past 4 months it hasn’t worked once. I’m curious if the camera is just bad or if there’s a fix I can do for it. Thanks Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 29, 2020 Report Share Posted December 29, 2020 I'd suspect either a defective camera or corrosion on the connector. Quote Link to comment Share on other sites More sharing options...
Dylan2012edge Posted December 30, 2020 Author Report Share Posted December 30, 2020 @enigma-2 so if the connector is corroded obviously I would need a new one but is it plug and play or id have to splice a new connector in. And thank u for the help Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 31, 2020 Report Share Posted December 31, 2020 Not necessarily. Just use an electronic contact cleaner on it. This what I've used with good success. https://www.amazon.com/dp/B000BXOGNI/ref=cm_sw_r_cp_apa_fabc_Y8s7FbAKJ72B4 Quote Link to comment Share on other sites More sharing options...
Dylan2012edge Posted December 31, 2020 Author Report Share Posted December 31, 2020 @enigma-2 ok thank u. I’ll give it a shot and I’ll see how it works out Quote Link to comment Share on other sites More sharing options...
PageDeb13 Posted January 10, 2021 Report Share Posted January 10, 2021 I have a 2011 Edge and my camera has done the same thing. Hasn't worked for about 2 years. Quote Link to comment Share on other sites More sharing options...
trigg Posted February 20, 2021 Report Share Posted February 20, 2021 On 12/31/2020 at 3:00 AM, Dylan2012edge said: @enigma-2 ok thank u. I’ll give it a shot and I’ll see how it works out any luck with this? Quote Link to comment Share on other sites More sharing options...
PageDeb13 Posted February 23, 2021 Report Share Posted February 23, 2021 I don't know if my camera not working is related however now while I am driving my main menu screen switches from the main menu to my radio sound settings. I have tried putting it on random screens to see if there is any connection and there is not. Doesn't matter which screen I am on. It also makes the tone as if I had actually pushed the on screen button to switch to the sound settings. I read on another site that the camera issue might be linked to the same module. Quote Link to comment Share on other sites More sharing options...
PageDeb13 Posted February 23, 2021 Report Share Posted February 23, 2021 Where would I find the connector for the camera to check for corrosion? Quote Link to comment Share on other sites More sharing options...
