Rough Idle P0303 code
u66q
Hi all. Issue just started 2 weeks ago.
 2016 Edge AWD 2.0 SEL
66500 miles.
After car sits for a day or two, I start it up and I get a rough idle for about 15 seconds. After that or if I touch the gas it smooths out. This time it gave a cel. I checked the code and it showed a P0303. I always use the same gas / gas station { Exxon } and keep maintenance up as required. Is there something I can check for before handing it over to the dealership ? I bought the car at a dealership 1.5 hrs. away , because dealerships here are spaced apart therefor alot more expensive on service and buying vehicles. Reason I mentioned that is , where I bought the car gives a lifetime powertrain warranty as long as I own the car but catch is , I have to have all service done there to keep the warranty. So i hate to take it 1.5 hrs away if there's something I can try first. Thanks for any advice you can give.
