08 Edge intermittent battery light
ace573
Hey all!
Yesterday my battery light came on. Drove for couple minutes, turned on lights as it got dark and light went off. Got home, checked with multimeter and alternator is charging(14.2V) and battery voltage is also good. Light is off. On  normal car I would replace the alternator, which I am leaning towards here as well. But since PCM controls Alternator on the edge I am wondering if something else might be happening?
Any thoughts?
4 hours ago, ace573 said:
Hey all!
Any thoughts?
The same thing happened to my 2010 SE last year. With the light off, everything was fine. With the light on, no charge from the alternator. Battery SOH = 100%, SOC = 98%. I changed the alternator (PITA) and haven't had a problem since.
55 minutes ago, handfiler said:
I  wouldn't buy a new battery until I actually confirmed that the battery is bad.
If it’s more than 3 yrs old it’s either bad or about to be bad.   Obviously it’s good to test it IF you have a digital tester that measures CCA and not the old style testers or voltmeters.  Those are worthless.
