07Bluesilver Posted September 10, 2021 Report Share Posted September 10, 2021 (edited) I have a code po010 on my Edge. I changed my VVT solenoid. camshaft sensor, fuel injector, spark plugs. I used to have a code po300 which I fixed, but then decided to put seafoam in my intake. Afterward the new code came up. That's when I changed my VVT and camshaft sensor also valve cover gaskets. When I took off the valve cover there was a lot of gunk all over. Now I'm doing an oil change and was thinking of doing a motor flush and see if I can get rid off the gunk. I'm not sure if to do the flush. Should I just do the oil change? To see if it helps and do another oil change within 1k miles. ANY INFO. WOULD BE GREATLY APPRECIATTED. THANKS!!! Edited September 10, 2021 by 07Bluesilver Quote Link to comment Share on other sites More sharing options...
Cerberus Posted September 12, 2021 Report Share Posted September 12, 2021 flushing a motor crank case can be problematic.. If i were in your situation, I'd probably be using something like Rislone (high detergent, not solvent) to clean out the internals. Also, I have had very good results with Mobil1 fully synthetic oils to avoid sludgy garbage inside my engines. no harm in just changing the oil, maybe much more frequently for a little while as a slow flush. One of the possible causes cited for P0010 is engine electrical harness failure / rub through.. check out this video too Quote Link to comment Share on other sites More sharing options...
07Bluesilver Posted September 15, 2021 Author Report Share Posted September 15, 2021 Thanks I did check the harness with a bolt meter. It was a bad wire. I got one from another Edge that looks to be good. I will install it on Saturday. After all the new parts, it turned out to be the wire. Thanks for the info. 1 Quote Link to comment Share on other sites More sharing options...
