bscott94 Posted April 4, 2022 Report Share Posted April 4, 2022 (edited) I was washing my car a few weeks ago and noticed the cover on the antenna is loose at the front of the fin. I've searched on here and only found antennas broken off completely. Does the cover pop on and off? Can I take it off and stick it back on with double sided tape or do I need to replace the whole unit for the cover to be mounted securely? Edited April 28, 2022 by bscott94 Quote Link to comment Share on other sites More sharing options...
bscott94 Posted April 28, 2022 Author Report Share Posted April 28, 2022 Does anyone have any experience with this? It looks like the cover might screw onto the base so I might have some broken plastic where it screws together but I can't find any info Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 28, 2022 Report Share Posted April 28, 2022 Attached is the service procedure for removal of the antenna. Satellite Radio Antenna.pdf 2 Quote Link to comment Share on other sites More sharing options...
bscott94 Posted April 28, 2022 Author Report Share Posted April 28, 2022 2 hours ago, omar302 said: Attached is the service procedure for removal of the antenna. Satellite Radio Antenna.pdf Thanks. Is there anything that says whether or not the plastic fin shaped cover can be removed from the base? I know there are things between the fin and the base so there has to be a way to get in there. I don't know if they're screwed/clipped together or if they're glued together after the internals are installed. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 28, 2022 Report Share Posted April 28, 2022 Looking at pictures of it (here), it seems it is attached with screws. 1 Quote Link to comment Share on other sites More sharing options...
bscott94 Posted July 23, 2024 Author Report Share Posted July 23, 2024 (edited) Well it finally happened. I got home Friday and the cover was missing. I think it was blown off in the touchless carwash. It only took like 15 trips through it. I ordered a used one on Ebay but it's white so I'm going to try to wrap it in in black carbon fiber vinyl. We'll see how that looks. @omar302, do you have the file for this in the instructions? 1. Lower the headliner. Refer to: Headliner  Lowering (50105 Interior Trim and Ornamentation, Removal and Installation). Edited July 23, 2024 by bscott94 Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 23, 2024 Report Share Posted July 23, 2024 Attached. Headliner - Lowering.pdf 2 Quote Link to comment Share on other sites More sharing options...
