Alex_May24 Posted February 19, 2023 Report Share Posted February 19, 2023 Hello, I'm currently tossing around the ideal of purchasing two 2019 edge housings with the led blade turn signal and two separate areas for the low and high beam lights. From my understanding these lights typically come with high optioned edges example titanium elite and 401a st trims. I own a 2019 ST trim it has quite alot on it expect for cooled seats and the what appear to be adaptive headlights. My question Is if I installed these higher trim adaptive led headlights into a edge that dosen't have adaptive led lights will the lights itself function as a normal headlight? Or just not function at all? I'm aware that the little silver headlight modules on the back of the housings are needed which the buyer I'm buying from has 2 perfect condition adaptive led headlights that came off a ST 401a trim. If anyone has any information or experience in this itll be much appreciated. Like I said I dont care too much if the adaptive portion doesn't work I just want them to function as normal upgraded headlights. If I can get the adaptive function working that's just icing on the cake. I've attached pictures of what I'm try to install and what I currently have. Thanks in advance everyone! Quote Link to comment Share on other sites More sharing options...
Perblue Posted February 19, 2023 Report Share Posted February 19, 2023 I haven't read or heard of anyone doing this. Unfortunately I think if you do it you'll be the guinea pig for it. If you do it let us know. Quote Link to comment Share on other sites More sharing options...
Alex_May24 Posted February 19, 2023 Author Report Share Posted February 19, 2023 I kinda figured that, I wasn't able to find any info on it either. Quote Link to comment Share on other sites More sharing options...
montymick Posted April 10, 2023 Report Share Posted April 10, 2023 Hi Of course, it is possible to replace your lamps with Bi-LED lamps. After assembly, you need to program the lamps using a program (for example FORSCAN). It is possible that the traba will move 2 wires in the lamp plug (high beams do not always work. Pins 1 <-> 10 are changed (at least in the European version). In Europe, it is additionally required that the lamps have automatic height adjustment. That's why we mount HCM modules with sensors on the front and rear swingarm. This system together with the appropriate camera in the rearview mirror works great!! Film in Polish language version. https://www.youtube.com/watch?v=kIZtRlKGVbM Quote Link to comment Share on other sites More sharing options...
itsjustdibella Posted Saturday at 05:26 PM Report Share Posted Saturday at 05:26 PM Of the two pictures are the ones at the top the normal headlights adn the ones under are the ones used for the adaptive front lighting system? Quote Link to comment Share on other sites More sharing options...
edjunior Posted 9 hours ago Report Share Posted 9 hours ago Welcome to the forum. Just wanted to let you know that you are replying to a thread that is 3 years old. Not a big deal, just wanted to let you know in case you didn't get a response from the OP. Quote Link to comment Share on other sites More sharing options...
