New Key Fob
I purchased a used 2013 Edge two weekends ago and only got one key and fob with it. They fob is in bad shape held together with zip ties, lol
So i bought two fobs of off EBAy and had one cut tonight. I watched a Youtube video on how to program the fob. Programing the fob went great, but the key will not start the car.
The dash lights up as if i just turned to the on position, but it doesn't acutally try to start the car.
Any ideas?
thanks
There is no easy way to program in a second key/fob for starting if you only have one. There are ways to do it with a program called "ForScan" on a computer and an obd-ii connector.
Both the IKT (Integrated Keyhead Transmitter) or the smart IA (Intelligent Access) keys require 2 so you can add one.
Programming in the remote access (unlock/lock/panic) is easy to do since when you do that, you have to program in all remotes at the same time, but the key security requires 2 existing keys.
Any ideas?
thanks
Try:
