O2 Sensors, DTC P0036
TXHoss
I have read about this code and the TSB 18-2212 for PCM reprogramming.  Since the reprogramming is $190 at my dealership, I figured I might as well replace the sensor to see if it is the actual issue.  Can someone show me where sensor 2 (downstream) is on the 2016 2.0L?  Thanks!!!
Edited by TXHoss
  • 4 months later...
I have the same problem.. I replaced the sensor but the problem persists.  I still have code P0036.  did you fix it?
