Jetboy47 Posted July 27, 2025 Report Share Posted July 27, 2025 I bought a service manual online for my 2023 ST and near the end of the drain and refill procedure it says once the leveling plug is put back in to add 2 pints. I've watched many videos on you tube and have yet to see anyone mention this. Below are steps 17 and 18 from the manual: 17. Install the oil leveling plug. Torque : 30 lb.ft (40 Nm) 18. Add 1L (2 pt) of clean transmission fluid. Material : Motorcraft® MERCON® ULV Automatic Transmission Fluid / XT-12-QULV (WSSM2C949- A, ) Can anyone else confirm that adding the extra two pints is correct. I wonder if they realized they needed to add more than they recommended in the past... 1 Quote Link to comment Share on other sites More sharing options...
boostededge Posted September 4, 2025 Report Share Posted September 4, 2025 (edited) Can confirm the 2019 ST FSM says the same thing. I'm getting ready to do my first fluid change at ~40K and will follow the FSM exactly. Edited September 4, 2025 by boostededge Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 4, 2025 Report Share Posted September 4, 2025 That is the 8F57 specs (full plus 1 quart), the 8F35 is just fill to the bottom of the sight plug. 2 Quote Link to comment Share on other sites More sharing options...
Jetboy47 Posted September 5, 2025 Author Report Share Posted September 5, 2025 6 hours ago, dabangsta said: That is the 8F57 specs (full plus 1 quart), the 8F35 is just fill to the bottom of the sight plug. Thanks dabangsta! Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted September 5, 2025 Report Share Posted September 5, 2025 That's interesting. My service manual doesn't say anything about adding fluid after installing the level plug. My service manual (on a CD) shows a published date of October 2018. Wonder if there was a revision to this procedure? Quote Link to comment Share on other sites More sharing options...
boostededge Posted September 5, 2025 Report Share Posted September 5, 2025 (edited) Heres from the 2019 Edge ST FSM. This one is a little easier to read than the 2022 one that was posted in the other thread. Both have you adding 1 quart at the end, after you install the leveling bolt for the final time. The 2022 one posted has more info on going through gears though and is not mentioned in the 2019 one. 2019_edge_transmission.pdf Edited September 5, 2025 by boostededge 2 Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted September 5, 2025 Report Share Posted September 5, 2025 (edited) thanks for posting those instructions. They are almost the same as mine except for the real pictures and the steps to add the additional fluid. I did notice there was a procedure revision date of 09/24/2021 so that explains my manual discrepancies. Perhaps I need to go back and add some fluid although I haven't noticed any drivability concerns. Or did this have something to do with the change from an 8 speed to a 7 speed transmission? Edited September 5, 2025 by kruzr1 Quote Link to comment Share on other sites More sharing options...
boostededge Posted September 13, 2025 Report Share Posted September 13, 2025 I confirmed with Bellevue Ford tech that their service manual says the same about adding 1L once full to the 2019+ ST. 3 Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted September 14, 2025 Report Share Posted September 14, 2025 Thank you for the confirmation. Quote Link to comment Share on other sites More sharing options...
Jetboy47 Posted September 14, 2025 Author Report Share Posted September 14, 2025 Appreciate that boostededge! Quote Link to comment Share on other sites More sharing options...
