Transmission Fluid Drain and Refill - Adding two pints / 1 liter after the oil leveling plug is put back in
Jetboy47
I bought a service manual online for my 2023 ST and near the end of the drain and refill procedure it says once the leveling plug is put back in to add 2 pints. I've watched many videos on you tube and have yet to see anyone mention this. Below are steps 17 and 18 from the manual:
17. Install the oil leveling plug.
Torque : 30 lb.ft (40 Nm)
18. Add 1L (2 pt) of clean transmission fluid.
Material : Motorcraft® MERCON® ULV Automatic Transmission Fluid / XT-12-QULV (WSSM2C949-
A, )
Can anyone else confirm that adding the extra two pints is correct. I wonder if they realized they needed to add more than they recommended in the past...
Heres from the 2019 Edge ST FSM. This one is a little easier to read than the 2022 one that was posted in the other thread. Both have you adding 1 quart at the end, after you install the leveling bolt for the final time. The 2022 one posted has more info on going through gears though and is not mentioned in the 2019 one.
2019_edge_transmission.pdf
Edited by boostededge
