Hollywood1 Posted September 10, 2025 Report Share Posted September 10, 2025 I just thought I would write a quick post about some maintenance that I performed yesterday. I am on my second edge ST now coming from a 2020 to a 2024. I've got about 16,500 miles currently. Yesterday I did a complete fluid change. The radiator fluid tested fine and was pretty easy to swap. The rear differential was very dark, almost black and the new fluid is a caramel color so it was definitely at the end of its life. The PTU wasn't as bad, but definitely a dark, dark brown whereas the new fluid again is a caramel color. I also figured that it would be a good idea to do a transmission drain and fill since I've been getting a hard 1-2 shift. The transmission fluid definitely had a slightly burnt smell to it and was nearly black and the new fluid is a red color. Just a heads up to anybody who is wondering about the maintenance intervals that Ford recommends, I would definitely do them early. I got all of those fluids from rock Auto for about $100. 1 Quote Link to comment Share on other sites More sharing options...
Jetboy47 Posted September 14, 2025 Report Share Posted September 14, 2025 I found the same on my ST at 20k for the RDU, it definitely needed changing. I bought my Edge used at 18k. I don't have a drain plug for the PTU so I sucked out half the fluid, like you the PTU fluid wasn't bad yet. I also drained 5 quarts of tranny fluid which looked fine. I'm hoping to keep it for the next ten years so I think I might just do the same every 10k as little as it costs. Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 14, 2025 Report Share Posted September 14, 2025 Doesn't the 2023 ST have a cooler that you pull to drain the PTU? Quote Link to comment Share on other sites More sharing options...
Jetboy47 Posted September 14, 2025 Report Share Posted September 14, 2025 No, mine does not have a cooler. There is a plug where the cooler would go. I tried finding a spare plug but it's often an unavailable part and it's close to $70 if you can find it. I'm not pulling it without a spare incase there is an issue with it. Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 14, 2025 Report Share Posted September 14, 2025 Would it only be a gasket that's needed to pull and re-install the dummy cooler plug? Quote Link to comment Share on other sites More sharing options...
boostededge Posted September 14, 2025 Report Share Posted September 14, 2025 PN: K2GZ-7A010-M from thread - 1 Quote Link to comment Share on other sites More sharing options...
Jetboy47 Posted September 14, 2025 Report Share Posted September 14, 2025 Yes a seal, but I'm not messing with it without a backup. They say you should replace the bolts too if removed (It's a kit with plug and blots). I'm still under warranty, so no matter what I'm good with pulling half of it every 10k and leave it be. Why they couldn't put a drain plug in it...frigging cost savings. Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 14, 2025 Report Share Posted September 14, 2025 All that's needed is an O-ring - the size number is found in the thread linked above. No way that the bolts are "one time use". Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted September 15, 2025 Report Share Posted September 15, 2025 20 hours ago, 1004ron said: No way that the bolts are "one time use". I don't think they are " one-time use " either but Ford is being cautious. It's like saying, on older cars, every time you change the oil you have to change the oil drain plug gasket. Not a true statement. It's very tight in there to remove that PTU cover plate without moving anything else. I chose to buy a MityVac unit specifically for vacuuming out the gear fluid. Sucked it almost dry. I used another MityVac unit, so I didn't have to clean them in-between same-time uses for the PTU, to pump the new gear oil in. Took the correct amount of fluid as specified in the manuals. ( That's why I said it sucked it dry ) And, of course, a lot less messier. 3 Quote Link to comment Share on other sites More sharing options...
Hollywood1 Posted September 15, 2025 Author Report Share Posted September 15, 2025 My 2024 has the cooler, and I used the suction method to get the fluid out. I wanted to remove the cooler but the studs to remove it are basically impossible to get a socket or wrench on so I gave up. 2 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted September 16, 2025 Report Share Posted September 16, 2025 My 2024 has the cooler as well. There was a previous thread where someone pulled the cooler out just enough to let the fluid drain out and put it back in using the same studs and o ring. One disadvantage to the cooler: it takes up more space in the ptu, reducing fluid capacity. Not sure how beneficial circulation 200 degree (plus) through the cooler could do much to help. 1 Quote Link to comment Share on other sites More sharing options...
