gdoug Posted October 1, 2025 Report Share Posted October 1, 2025 Hello everyone, We have a 2013 Limited that has just under 70K miles on it. Lately the brake pedal will randomly go to the floor easily with minimal braking happening. After pumping the brake pedal, pressure comes back. It won't do it again sometimes for weeks. It doesn't do it frequently enough for a service technician to be able to duplicate the issue. There are no warning lights on the dash. It could be a master cylinder, but I have also read the ABS module could cause this? Has anyone had this happen and what was the fix? Thanks Quote Link to comment Share on other sites More sharing options...
my 2012 edge Posted October 1, 2025 Report Share Posted October 1, 2025 i did on my 2012. it was the brake booster i think it was a recall 1 Quote Link to comment Share on other sites More sharing options...
gdoug Posted October 2, 2025 Author Report Share Posted October 2, 2025 No brake booster recall for the 2013. The only recall listed is a door latch recall. Quote Link to comment Share on other sites More sharing options...
hlg013 Posted October 8, 2025 Report Share Posted October 8, 2025 Same story on my 2013. Get the booster checked out. Quote Link to comment Share on other sites More sharing options...
Teltec69 Posted January 9 Report Share Posted January 9 (edited) Same problem on my 2013. I replaced the booster but it did not help! Edited January 9 by Teltec69 Quote Link to comment Share on other sites More sharing options...
makaveli3004 Posted January 18 Report Share Posted January 18 I had the same problem, first time was the brake booster, 2nd time was the abs module that had to be done by the dealer. Cost $2000 Quote Link to comment Share on other sites More sharing options...
gdoug Posted March 9 Author Report Share Posted March 9 Hello, our 2013 Edge brake pedal randomly gets very soft. You have to go to the floor with it to get any braking. Once you cycle the pedal several times, pressure comes back. This happens so infrequently, it's hard to know what's really going on. I immediately suspect the master cylinder, but wanted to know if anyone else has experienced this and what the fix was. The car has just under 70K miles and is still on the factory brakes. I'm thinking about trying a pressure bleed on the whole system first. Thanks Quote Link to comment Share on other sites More sharing options...
