koof Posted January 27 Report Share Posted January 27 Currently running 245/60R18 winters and looking to pick up new rims and tires in the spring. With any tire and/or rim size calculator for the SEL trim only shows 18" or lower for sizes but if I select Sport trim I can choose 20's. Should I be safe grabbing 245/50R20 tires and rims? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted January 27 Report Share Posted January 27 Those two tires are basically the same diameter and revs per mile, so as long at the wheels are up to spec as well (offset, width, etc) then they would be fine. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted 1 hour ago Report Share Posted 1 hour ago Thread is a little old. My car went from 18's to 20's. 20's look better (a lot better), but, the ride is much harsher. (Less sidewall.) I use the quietest and smoothest I could find (actually Michelin's are quieter and smoother, but they only last 20-25k before they get loud and rough), so I now use Pirelli Scorpion's. So if you move up to 20's, get rims from a reputable dealer and the best tires you can find. Cheap tires are horrible. (From experience. One week and took the back and uograded.) Quote Link to comment Share on other sites More sharing options...
