Computer Problem? Stiff steering. Automatic Acceleration
Hello all.
I have a 2016 2.7L MKX and have an issue with power steering and instrument cluster lights(pics below). I posted here since Edge is the same platform and there aren't many Lincoln DIY sites.
Car is drivable but the steering is a little stiffer than normal. Also, on occasion, the engine will go into a louder cadence and accelerate while in drive. Not by much but enough to keep you from slowing down when you take your foot off of the accelerator pedal. If you put it in park while this is happening, the engine will rev to 3000-4000 Rpms on own and almost sounds as if it's switching gears but the car isn't in gear. Has anyone had this happen before? So far I've checked battery and alternator. Both passed.
