BCM problems???
JLBoh
Hi everyone, I’m new here and praying for some help.
a couple days ago I was leaving work and noticed my back parking lights were on. Today when leaving work my AC was not working. When I got home, no AC, no lights off and now my lift gates is not working😔
 can anyone help please? 2013 ford edge sport. FWD
  • 5 weeks later...
A weak vehicle battery can cause all kinds of weird faults. Verify your battery is good by running a conductance test (a CCA test). (Not just a simple voltage test which is misleading. A battery may present 12.6 volts at rest but drop voltage quickly. A CCA test measures how much capacity the battery can deliver before its voltage drops.) Low voltage can cause digital electronics to malfunction.
20 hours ago, JLBoh said:
Thank you! I took it to Firestone and I did need a new Battery😊
And everything is now working as it should?  As enigma said, battery issues can cause all kinds of weird problems.
Posted (edited)
So far so good! 😊 Thank you!
Edited by 1004ron
