JLBoh Posted April 26 Report Share Posted April 26 Hi everyone, I’m new here and praying for some help. a couple days ago I was leaving work and noticed my back parking lights were on. Today when leaving work my AC was not working. When I got home, no AC, no lights off and now my lift gates is not working😔 can anyone help please? 2013 ford edge sport. FWD Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 26 Report Share Posted May 26 A weak vehicle battery can cause all kinds of weird faults. Verify your battery is good by running a conductance test (a CCA test). (Not just a simple voltage test which is misleading. A battery may present 12.6 volts at rest but drop voltage quickly. A CCA test measures how much capacity the battery can deliver before its voltage drops.) Low voltage can cause digital electronics to malfunction. Quote Link to comment Share on other sites More sharing options...
JLBoh Posted May 26 Author Report Share Posted May 26 Thank you! I took it to Firestone and I did need a new Battery😊 2 Quote Link to comment Share on other sites More sharing options...
edjunior Posted May 27 Report Share Posted May 27 20 hours ago, JLBoh said: Thank you! I took it to Firestone and I did need a new Battery😊 And everything is now working as it should? As enigma said, battery issues can cause all kinds of weird problems. 1 Quote Link to comment Share on other sites More sharing options...
JLBoh Posted May 29 Author Report Share Posted May 29 (edited) On 5/26/2026 at 9:52 PM, edjunior said: And everything is now working as it should? As enigma said, battery issues can cause all kinds of weird problems. So far so good! 😊 Thank you! Edited May 29 by 1004ron Quote Link to comment Share on other sites More sharing options...
