ArkansasEdge Posted July 6 Report Share Posted July 6 Finally got around to installing the LED strip to the hood yesterday. While I was at it I installed the hood insulator pad. i wanted to have an OEM as possible look, so I used wire looms, split looms for positive and negative terminals. Didn’t take a photo, but used a fuse tap like others have. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 6 Report Share Posted July 6 A photo from the front in the dark would be good. 1 Quote Link to comment Share on other sites More sharing options...
ArkansasEdge Posted July 6 Author Report Share Posted July 6 3 hours ago, 1004ron said: A photo from the front in the dark would be good. 4 Quote Link to comment Share on other sites More sharing options...
ArkansasEdge Posted July 6 Author Report Share Posted July 6 Here’s the startup sequence. I can provide more details regarding installation if anyone is curious, but there’s been a lot of write ups. https://youtube.com/shorts/rpfmqZ-IEiI?feature=shared Quote Link to comment Share on other sites More sharing options...
fishx65 Posted July 7 Report Share Posted July 7 Looks awesome!!! Does the color temp match the OE headlight led light strips pretty good? Can you please post a link to the exact strip you ordered and the length. Quote Link to comment Share on other sites More sharing options...
ArkansasEdge Posted July 11 Author Report Share Posted July 11 Thanks! Yes, the color pretty much matches OEM led color temp. Did you see the YouTube link I shared? You can watch the full startup sequence. Below is the one I bought. If you want any additional install info or tips, feel free to DM. UHANBUT 71 Inch Exterior Car LED... https://www.amazon.com/dp/B0FCBRJ7PT?ref=ppx_pop_mob_ap_share Quote Link to comment Share on other sites More sharing options...
fishx65 Posted July 15 Report Share Posted July 15 Thanks AE, just ordered the one you posted. I'm hoping it's the same quality as the LED strip I installed for the cargo area. Quote Link to comment Share on other sites More sharing options...
BlueSteel Posted July 15 Report Share Posted July 15 2 hours ago, fishx65 said: Thanks AE, just ordered the one you posted. I'm hoping it's the same quality as the LED strip I installed for the cargo area. I'm also curious about the cargo area. Which one did you buy for that, @fishx65? Quote Link to comment Share on other sites More sharing options...
fishx65 Posted July 16 Report Share Posted July 16 I ordered two different ones and compared them. This one was way brighter than the other one I ordered: https://www.amazon.com/dp/B0FM3KWLLG?ref=ppx_pop_dt_b_asin_title&th=1 Very easy install and adds a ton of light to the cargo area. 1 1 Quote Link to comment Share on other sites More sharing options...
