Another LED hood strip install
Finally got around to installing the LED strip to the hood yesterday. While I was at it I installed the hood insulator pad.
i wanted to have an OEM as possible look, so I used wire looms, split looms for positive and negative terminals. Didn’t take a photo, but used a fuse tap like others have. IMG_6433.thumb.jpeg.530fc539a7f7889b078178b28084e58f.jpegIMG_6434.thumb.jpeg.b0596e31b071e1b2c8391ddd80093381.jpegIMG_6435.thumb.jpeg.01c8f3b4d58afc628ea9af661654afff.jpeg
Thanks! Yes, the color pretty much matches OEM led color temp. Did you see the YouTube link I shared? You can watch the full startup sequence.
Below is the one I bought. If you want any additional install info or tips, feel free to DM.
UHANBUT 71 Inch Exterior Car LED... https://www.amazon.com/dp/B0FCBRJ7PT?ref=ppx_pop_mob_ap_share
