22CarbGrayElite Posted August 9 Report Share Posted August 9 (edited) Finally got started on the install today. Going in is a Kicker 10” down firing sub box, an AudioControl Epic 500 amp and an AudioControl LC2i LOC. This sub was going to used in my previous vehicle but that never came to fruition, so I am going to use it in the Edge. So far, I have tapped the stock subwoofer wires for signal and ran them to the spare tire area. I also ran the 4 gauge power wire from under the hood to the cabin. My initial plan was to mount the amplifier and LOC under the cargo floor panel, but after receiving the goodies from Crutchfield and glancing under the front seat, I decided to mount the amp and LOC under the front seat. They will get plenty of air flow and it will make tuning the stuff easier. The seat will not interfere or come into contact with the components or wiring. Edited August 9 by 22CarbGrayElite Hit send too quickly Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 9 Author Report Share Posted August 9 Today I mounted the amp and LOC under the seat. I bought a piece of plexiglass from Lowe’s and cut it slightly larger than the amp. I then put it under the carpet and screwed the amp down to it. I screwed the LOC down to the plastic cover that covers the seat control module. I fished the amp power wire under the carpet and it is ready to be cut and hooked up. At this point, I am ready to ground the amp, hook the power wire, hook up the sub speaker wires and hook the signal and RCA cables up. Since I am using two AudioControl components, they included a power wire harness with the amp along with an imbedded one amp fuse, to power the LOC, simplifying the install. All I have to decide is whether to let the amp automatically sense the signal and turn on both components or run a remote turn on wire. Pics in the next post showing progress and hopefully to help someone else planning to do an install. Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 10 Author Report Share Posted August 10 Power wire run… Don’t know how some did this without removing the battery. Took 10 minutes to remove the battery and it gives full access to the grommet, although the brake fluid distribution block does sit somewhat in front of it. I poked a long screwdriver through the divot and then taped a 12 gauge wire to my 4 gauge wire and pulled in through from the engine side into the cabin. Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 10 Author Report Share Posted August 10 (edited) The Kicker sub, 48CVTDF102, 10” CompVT sub rated at 350 watts RMS @ 2 Ohms. This was originally bought to go in my Acadia as it fit perfectly between the second row captains chairs on the floor. That install never happened and the sub sat brand new on the shelf, until now. Edited August 10 by 22CarbGrayElite Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 10 Author Report Share Posted August 10 The AudioControl Epic500 amp, which will feed the sub 350 watts RMS @ 2 Ohms, and the LC2i line out converter… Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 10 Author Report Share Posted August 10 Amplifier installation wiring is a KnuKonceptz Kolossus 4 gauge OFC power and ground kit along with a set of short Klarity RCA cables, a mini ANL fuse holder and 12 gauge speaker cable. They also include 20’ of remote wire. KnuKonceptz has been at the amplifier and speaker wire game for a long time and has a stellar reputation for reliability. Their amp wiring kits are significantly cheaper than Crutchfield’s offerings as well. I also have the Metra ANC bypass cable as well. I haven’t hooked that up yet as I want to see what the AudioControl LC2i can do with its Accubass settings. Hopefully I can finish this install next weekend and get it dialed in. Quote Link to comment Share on other sites More sharing options...
edjunior Posted August 10 Report Share Posted August 10 Nice man! 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 13 Report Share Posted August 13 Just seen your post, otherwise I would have spoken up sooner. This may be a mistake. Taken from page 192 of a 2022 owners manual: WARNING: Vehicle modifications involving braking system, aftermarket roof racks, suspension, steering system, tire construction and wheel and tire size may change the handling characteristics of your vehicle and may adversely affect the performance of the electronic stability control system. In addition, installing any stereo loudspeakers may interfere with and adversely affect the electronic stability control system. Install any aftermarket stereo loudspeaker as far as possible from the front center console, the tunnel, and the front seats in order to minimize the risk of interfering with the electronic stability control sensors. Reducing the effectiveness of the electronic stability control system could lead to an increased risk of loss of vehicle control, vehicle rollover, personal injury and death. Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 17 Author Report Share Posted August 17 On 8/13/2026 at 4:23 PM, enigma-2 said: Just seen your post, otherwise I would have spoken up sooner. This may be a mistake. Taken from page 192 of a 2022 owners manual: WARNING: Vehicle modifications involving braking system, aftermarket roof racks, suspension, steering system, tire construction and wheel and tire size may change the handling characteristics of your vehicle and may adversely affect the performance of the electronic stability control system. In addition, installing any stereo loudspeakers may interfere with and adversely affect the electronic stability control system. Install any aftermarket stereo loudspeaker as far as possible from the front center console, the tunnel, and the front seats in order to minimize the risk of interfering with the electronic stability control sensors. Reducing the effectiveness of the electronic stability control system could lead to an increased risk of loss of vehicle control, vehicle rollover, personal injury and death. If the amp and LOC prove to be an issue, I will move them to the cargo area. I have installed amps under the seats of a 2014 Impala I once owned and never had any problems. We shall see, good to know regardless. Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 17 Author Report Share Posted August 17 Made a little more progress today, but I had a set back that prevented me from finishing. As some of you may know, the fuse panel under the dash is in a miserable spot and accessing it is a PITA. There are three major wire harnesses attached to it. Well, in my efforts to check and test for switched and constant power, I managed to loosen the latch lock to the middle harness and my issues eventually began. The key fobs stopped working, the car went into battery protection mode, the car wouldn’t go into accessory mode or power on/engine off mode, let alone start. I was beside myself. I had to call my daughter to come get me and go get my battery charger and scan tool. After doing my due diligence, I called a knowledgeable friend who walked me through a couple of things, one of which was checking a certain fuse in the panel, and that was when I discovered the loose connector. The scan tool told me communication was lost to the BCM and the push to start button was stuck ON. Couple that with everything else, and no flashers or horn, it was frustrating. I snapped that connector back it and secured it and everything came back to life like it should. Note to anyone going into that fuse panel under the dash… be mindful of those harnesses and double check they are secured properly before you call a tow truck. I have signal wires hooked up, the power harness for the LOC ready to be plugged in, and power, ground and remote for the amp ready to be cut to size and plugged in. Sub wires are also ran and ready to be plugged. Last is the amp fuse. Realistically, this is an hour or two of work and it will be running. Hopefully there will be no more set backs or being pulled away to do something else and. It being able to get back to it. 2 Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 24 Author Report Share Posted August 24 Finally finished up the install last night. I have to dial everything in but so far it sounds decent for what it is. I was lightly bumping it last night and didn’t have any issues with any interference or other abnormalities. Will definitely need more time with it to see if anything arises. One thing I learned about the Audio Control GTO turn on feature… the Ford Edge doesn’t play well with it. Disable it and run a typical switched remote wire and call it good. For the switched circuit, I used fuse F2 in the car fuse block with a fuse tap. Easy enough but just an absolute pain to get to that fuse box. Another tip… I grounded the amp and LOC to a bolt along the door sill that secures the plastic trim that lets the interior plastics snap down into place. I took a wiz wheel and scuffed the paint down to bare metal and hooked it up. Once I get the output and gain set on the amp, I’ll update with my impressions. I could be inclined to swap the stock sub for a Kicker 8” DVC shallow mount sub just to see what happens, but I doubt that will be necessary. I just want to sound good in the car, not from three blocks away. 1 Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted August 27 Author Report Share Posted August 27 And I am now on hold with this project. My Edge is at the Ford dealership having transmission problem repaired. Made a post in the Ecoboost section about this if you are interested. When I get it back, I am going to install the Axxess ANC bypass harness which is behind the touchscreen. I am also going to install the dash storage bin with lid that I bought from Ford a couple of weeks ago. Once that is done, I need to set the Accubass on the LOC and set the gains on it and the amp. 1 Quote Link to comment Share on other sites More sharing options...
