2010 Ford Edge AC issues
zfar2
2010 Ford Edge AWD Limited with dual AC control. Both blend door actuators are working properly but the driver side is not blowing as cold as the passenger side. I removed the left side actuator and checked the linkage which seems to move without any issues and I can hear the door close. Installed a new actuator and recalibrated the blend doors resulting in the same issue deiver side is not as cold. HELP if you have any experance I am all ears...
  • 1004ron changed the title to 2010 Ford Edge AC issues
