Summers22 Posted Friday at 06:54 PM Report Share Posted Friday at 06:54 PM Trying to help my daughter with her car. Multiple codes, reduced power and very sluggish acceleration up until 40mph. No check engine light. List of codes: ABS Antilock braking system : DTC Description Status U0140:00:20 Lost Communication With Body Control Module CMDTC U0265:00:20 Lost Communication with Image Processing Sensor A CMDTC U2107:00:68 Collision Mitigation By Braking CMDTC U3003:16:60 Battery Voltage CMDTC PCM Powertrain Control Module: DTC U0284:00:68 Description Lost Communication with Active Grille Air Shutter Module 'A' CMDTC Quote Link to comment Share on other sites More sharing options...
1004ron Posted 12 hours ago Report Share Posted 12 hours ago The symptoms you describe suggest it was in "Limp Mode" but if that was the case the CEL would be on and a code set. What are you using to scan for codes? Quote Link to comment Share on other sites More sharing options...
Summers22 Posted 11 hours ago Author Report Share Posted 11 hours ago I am using a TopDon Artidiag500. Thats the odd thing, no check engine light. Part of me things it could be a torque converter issue and a transmission drain and fill would help. Google AI says all symptoms point to a bad battery, I did replace it in August of 25 and did the BMS reset with the same scanner. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 11 hours ago Report Share Posted 11 hours ago Based on many reports here and elsewhere I don't have much confidence in scan tools other than Forscan. If there really isn't any related codes then it will need more in depth diagnostics - display live data such as fuel trims etc. Quote Link to comment Share on other sites More sharing options...
Summers22 Posted 9 hours ago Author Report Share Posted 9 hours ago O'Reilly says bad battery, going to get it replaced now. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 8 hours ago Report Share Posted 8 hours ago 21 hours ago, Summers22 said: reduced power and very sluggish acceleration up until 40mph. 47 minutes ago, Summers22 said: O'Reilly says bad battery, going to get it replaced now. If the alternator is working I don't see how the bad battery will cause the symptoms you describe. Quote Link to comment Share on other sites More sharing options...
