lalondem_98 Posted 6 hours ago Report Share Posted 6 hours ago (I will put a video if requested). My engine is balancing, rocking, back and forth slowly and smoothly and the electrical lights are flickering...engine is perfectly fine otherwise...rings any bell? One thing odd is the the OBD port reports a battery voltage fluctuating continously from 16.5 volts to 14.5 volts. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 4 hours ago Report Share Posted 4 hours ago On 9/6/2026 at 4:39 PM, lalondem_98 said: For the alternator it is a rebuilt one, not an OEM. 1 hour ago, lalondem_98 said: (I will put a video if requested). My engine is balancing, rocking, back and forth slowly and smoothly and the electrical lights are flickering...engine is perfectly fine otherwise...rings any bell? One thing odd is the the OBD port reports a battery voltage fluctuating continously from 16.5 volts to 14.5 volts. Suspect alternator. Quote Link to comment Share on other sites More sharing options...
