lalondem_98 Posted 17 hours ago Report Share Posted 17 hours ago (I will put a video if requested). My engine is balancing, rocking, back and forth slowly and smoothly and the electrical lights are flickering...engine is perfectly fine otherwise...rings any bell? One thing odd is the the OBD port reports a battery voltage fluctuating continously from 16.5 volts to 14.5 volts. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 15 hours ago Report Share Posted 15 hours ago On 9/6/2026 at 4:39 PM, lalondem_98 said: For the alternator it is a rebuilt one, not an OEM. 1 hour ago, lalondem_98 said: (I will put a video if requested). My engine is balancing, rocking, back and forth slowly and smoothly and the electrical lights are flickering...engine is perfectly fine otherwise...rings any bell? One thing odd is the the OBD port reports a battery voltage fluctuating continously from 16.5 volts to 14.5 volts. Suspect alternator. Quote Link to comment Share on other sites More sharing options...
lalondem_98 Posted 10 hours ago Author Report Share Posted 10 hours ago would the alternator be able to provoke the engine into balancing? Quote Link to comment Share on other sites More sharing options...
