Bad PCM's TSB
hill392
I have recently expierenced problems with my 2007 Edge. Started out as sudden loss of power, missing, sputtering and a burnt smell. Code reader showed faulty COP coils. Upon further examination one of my COP coils was severly melted. Talked to the dealer 3 weeks ago where they said mine was they second one they have seen but no TSB had been issued as of then addressing the problem. Ford has since then released a TSB addressing the problem. Seems there are some faulty PCM's out there causing the COP's to stay on thus melting the COP coils. Ford is replacing all of the COP coils, spark plugs and PCM at no cost to the owner. There are some stipulations for the vehical to qualify, one being 80,000 miles or less. Hope this info. will help someone. Hats off to Ford for making this right..
  • 5 months later...
As you may have seen in my other thread, Ford is not accepting the liability across the board. Although I quailfy for the warranty (based on the TSB and emissions warranty), I was told to piss off.
I suspect this problem is much bigger than it appears on this forum. The Escapes are having the same problems, as well as the Fusion. When you lump them all together, sounds like alot of exposure or Ford.
TSB attached.
Ford TSB 11-8-2.pdf
Edited by Pete K
