Everything posted by EDST777
Hello. Guys, I have problems with change of an automatic transmission fluid in an automatic transmission. Problem that wanted to change liquid by removal of a branch pipe going from a cooler of an automatic transmission fluid in an automatic transmission as it is told here on YouTube but when I hoisted the car on the hoist, I couldn't find entrance and output hoses! ! ! ! ! These hoses aren't found (are inaccessible) from below (from a bottom), and in general from below very much it isn't convenient to approach any hoses, even what it is possible to see. I could see two hoses which as I think, are hoses specified in drawing in figure 3. These hoses are fixed by plastic loose straps, or it seemed to me, what they plastic? Whether I reflected I can to return them back if I remove or these loose straps disposable? Maybe for removal of hoses it is necessary to remove a bumper? Somebody did liquid replacement with removal of hoses (without commixing of liquids) or all did liquid change by a way of partial replacement without removal of hoses (dumping - filled in - ignited - run of 3 minutes and so three times)? I ask to tell in more detail how to remove hoses and how hoses to fix when them you return into place? Or it is better not to remove hoses at all what not to have problems? Thanks.
Guys, so in what there was a problem with pushes when switching from P in R? How the problem was solved?
Guys, I have no opportunity at present to get Motorcraft Mercon V liquid, but I have opportunity to get Valvoline MaxLife ATF liquid http://www.ebay.com/itm/Valvoline-ATF-MaxLife-Automatikgetriebeol-Vollsynthetisch-12-x-1L-ATF-Oel-/201158844282? pt=Autopflege_Wartung&hash=item2ed6005f7a On packing admissions are specified: Valvoline ATF MaxLife 12 Liter in 12Dosen zu je 1L empfohlen für alle Fahrzeuge mit mehr als 100.000 Km Laufleistung Freigaben/Leistungsstufen: GM Dexron IID, IIE, III, VI Ford Mercon, Mercon V Allison C-4, TransSynd, TES-295 BMW LT 71141, LA 2634 MAN 339 Ausgabe Z1, Z2, V1, V2 Mazda Mini Cooper CVT EXL 799 Toyota T, T-11, T-IV Chrysler ATF+3 Mitsubishi Diamond SP-II, SP-III Honda ATF-Z1 Nissan D, J, K, - matic Volvo 1161521, 1161540 Audi G0520250A2 GM9986195 ZF-TE-ML-14B, 16L, 17C JWS 3309 Voith G607, 1363 KIA SP-II, SP-III Suzuki VW TL 52162 Mercedes-Benz: 236.01 236.02, 236.03, 236.05, 236.06, 236.07, 236.08, 236.09, 236.10 und 236.11 und weitere Color of liquid - red. Me excites that there are no instructions on XT-5-QM. I can use this liquid for replacement? What your opinion?
Thanks friends.
Thanks friends. The fuel filter - in a fuel tank means!
Thank you for the answer. Thus I prepare for ATF Mercon V transmission oil replacement and as I am going to replace liquids in PTU and RDU. As it will influence fuel consumption I will report here for an example. I will look for at this forum of a subject about replacement of liquids in PTU and RDU. If someone can show them I will be grateful. Thanks for the help.
Hello. Friends I own Ford EDGE 2008 3.5 AWD Limited. Fuel consumption in the city 12.58 MPG. 93% a driving around the city with an average speed on the computer of 25 kilometers per hour. 7% of a driving on the highway, with a speed of 120 - 140 kilometers for an hour - fuel consumption in the country 19.6 MPG. My fuel of 92 units. I did replacement of all sparks of ignition(OEM). At such driving it is normal? Thanks. P.s. On my odometer run of 71300 miles.My wheels of 20 inches and in the winter and in the summer, in the winter fuel consumption increases to 11.2 MPG, because of low temperature of-28 degrees Celsius.Other problems it isn't observed on my supervision with the engine. At a start of motion when the car leaves from a parking sometimes when transfer selector in an interval between P and R there is a small push, especially if the car a little under an inclination costs, but I read that such is at many. I mean, what there can be my transmission increases in any way an expense, such it is possible? Guys at whom else such expense in the city at such average speed? I have in the city frequent dispersals stops on traffic lights, therefore average speed not the big.
Hello guys. I own FORD EDGE 2008 Limited AWD 3.5. My run of 114 000 km. I wish to replace an automatic transmission fluid in an automatic transmission and there are problems in the solution of this business. I don't know what automatic transmission fluid was filled in pregoing time because I am the second owner, the car was shipped on 83 000 km. According to the user manual replacement by Dexton VI is recommended, usually it is liquid of red color, for example as here: on 06.18 minute. But I filled in yellow liquid and I don't know a brand. I think to make full replacement independently three times that I worry to mix liquids. Whether report someone on services applied a yellow automatic transmission fluid? Whether replacement on red is possible, for example, after all the part of liquid, even small, remains not replaced? As far as my replacement and how me to avoid possible troubles will be dangerous? Thanks.
Friends who installed xenon in fog lights? Instalyation is worth it? Whether there are photos? Thanks! As report who I installed in Ford EDGE 2008 instead of hir2 12v 55w quartz-halogen bulbs, for example the such http://www.aliexpress.com/item-img/2pcs-Super-White-9012-HIR2-12V-55W-Headlight-for-Ford-Edge-Free-shipping/1739223158.html? Thanks!
Hello. That who changes often rubber with winter for the summer has a problem with chromic caps. It is possible to damage and break off them easily a piece when the tire slides too much a disk. I ask you who has such problem and how you cope with it? I tore off the chromeplated caps and I go without them. Tell on what glue such caps if I want them to paste back are glued?
Thanks! Unless nobody knows layout in the car of the fuel filter?
People where the fuel filter is set, nobody knows about it?
Hello. Friends, I own Ford EDGE 2008 Limited 3.5 AWD. I understand that I installed Lifetime the fuel filter, but nevertheless I know it it is possible to replace and someone it does each 10 000 km. I want to learn where it is installed? According to my assumptions the fuel filter is installed in a fuel pomp in a tank. Whether so it? Friends who knows the exact answer? ! Thanks. Express your opinions. Thanks!
Hello. Yes, you correctly understood. Thanks for the response. What engine at you is set 3.5 or another? Whether you change the fuel filter? Thanks.
Thanks. Style of driving quick), but without fanaticism! But I think that 19 liters on 100 kilometers it all the same are a lot of. You had earlier EDGE 2008 AWD? What octane number your fuel 92,95,98 had? What expenditure at your new EDGE? ! Thank you!
Hello. I own for EDGE 2008 3.5 Limited.My a consumption of gasoline around the city 19 liters / 100 kilometers (a city cycle). Outside the city on the route (autobahn) of 12,5 liters / 100 kilometers. I am disturbed by such big expense. My run of the car of 104 000 kilometers. I think to change all sensors of oxygen. Question to you, yours faithfully: - what number of sensors of oxygen on this engine? - there are people who already changed oxygen sensors? I will be grateful for any information and comments. Thanks.
I have the same expenditure in the city and in the country. Climatic conditions as in Canada. I am surprised as on AWD receive the expenditure of 12 liters on 100 km? !
Brake Shoe(Emergency Brake)replacement
EDST777 replied to EDST777's topic in Brakes, Chassis & Suspension
Excuse the correction intesno it is necessary to read as interestingly) 1
