EDST777
Everything posted by EDST777
  1. Help.To me such numbers met 7T4Z 3A329B 7T4Z3A329BD DT4Z3A329A 8T4Z3A329A 7T4Z3A428D what of them will be a worker of Ford EDGE 3.5 2008 AWD Limited 2FMDK49C08BA19802 for me?
  2. Faced now with a problem: on a dirt road, the car shook and the dipped headlights disappeared, drove to the place on fog lights when he removed the key from the ignition, it did not turn off the light of the side lights in front, apparently the contacts in the PCM block stuck. I removed the battery clip for 40 seconds, but it didnt help, I left the car without a clip until the morning. We had such similar problems in the group, what can this be connected with, what can be checked? Please any thoughts... In the spring I had a case when the parking lights did not turn off, then the problem was solved by removing the battery clack and until this time the problem did not manifest. I fear that it is a PCM fault, can be fixed without changing the control unit, can be tested something else ? If you change the control unit, then how to select it from the secondary market, so as to avoid programming. Is it possible to repair the base element of my block of failure? Many questions , please any thoughts. ...also I found information that it may be a problem of the light switch headlamp , which forward Check and how?
  3. Hi, how do you rate the rear suspension trimmers of the car , such as Bilstein 19282992 or better to choose something else?
  4. Hi. I want to clarify the type of oil in my Ford EDGE 2008 AWD Limited. In the guide . which may be out of date specified oil type with WSP M2C197-A SAE 80W-90 tolerance , but I read that now recommend it to replace by 75W-140 other oils, Ford WSS-M2C192-A compliant specifications or at least me on 75w-90. What choice do I have? I have a normal mode, without trailer, mainly it is an urban cycle, summer 25 (77F)-30 ( 86F) degrees Celsius, zmimy -15 (-59F) to -30 (-86F) degrees Celsius .
  5. hi, should I lubricate the bolts with copper grease when installing CA Control ARM or is this an unnecessary step? Also ask to explain why you need the replacement of front bolts , as it is necessary, they seem quite strong , more than class 10, anyone heard about problems because of these bolts?
  6. Hello, when do you recommend the replacement of front control arms if the car is 17 years 10/2007 year of manufacture , 2008 model year and 202,000 km ? Do you need to do it and will it make driving more comfortable, that is, will the car become softer and so on...?
  7. hi, what are the signs of replacing struts and amortisers and springs? Everything is fine with the car’s behavior, but recently there was a slight vibration from asphalt in the city, I seem to feel all these roughness and waves, but the car does not rock , what can be ? Amortissers, springs? now I have 202,000 km and I have never made this replacement...
  8. Hi, you have installed the OE Bosch 15719 sensors in your Ford EDGE 2008 ?
  9. Hi, what model of sensors did you install?
  10. Thank you for your help, I appreciate it, your experience is important to me. The question about the Bosch 15719 sensor came up because I was looking at reviews on amazon for this sensor, and there were any number of people who had experienced failure when installing a non-genuine sensor, even when it was listed as a suitable replacement. Bosch commented that this is due to the sensor being larger than the original or having a longer wire, perhaps this is just a formal response from Bosch, but I thought I'd clarify. If you have installed this particular sensor that would be a good sign for me to buy. Also wanted to clarify, if the low flow sensors do not affect the formation of the fuel mixture (as I understand they give a signal only when the catalyst is defective), can I just replace the two upper flow sensors, because my low flow sensors do not give now errors, my task to reduce fuel consumption, and this is the work of the upper flow sensors. What do you think about this ? any thoughts.....
  11. also want to clarify the following: on rockauto system gives two types of sensors: BOSCH 15724 for down stream and BOSCH 15755 for up stream. BOSCH 15724 is twice as cheap, does this mean that I can buy 4 BOSCH 15724 sensors, which will work like two overhead flow and two downstream flow. You said they were functionally and technically identical?
  12. Hi! Thanks for the valuable information about oxygen sensors! Very few details about these sensors, very little information when they need to be replaced. My observations are that the owners of the Ford EDGE replace them when there is any error on these sensors, but now we know from this topic that the sensors need to be replaced. This is the preamble. I own the 2008 FORD EDGE AWD , I now have 202,000 km and I’ve never changed these sensors since I bought a car for 80,000 km in 2011. My gasoline consumption in the summer is 17 liters per 100 km, in the winter it’s 19 liters per 100 km , where I live frosty winters, winter weather is like the weather in Canada, average temperature from -10 to -20 degrees C . I would like to replace these sensors, but should I buy BOSH or can I use for example also Stellox?
  13. EDST777
    Poor gas mileage
    why change the solenoids, they are reliable enough, what can happen to them, what kind of damage?... it seems to me that it is possible to replace rubber rings, seals on them and this will be enough, perhaps I do not know about something....
  14. Hi, what was the problem, how did you solve it?
  15. Hi. An interesting question is, at what time after the car is released to change the fuel pump, when the car has already traveled more than 200,000 km, and the car is a 2008 model, all-wheel drive, it is also important that most of the car’s service life is These are short trips. There are no obvious problems, it works without noise, but what worries me is that on the highway, during emergency acceleration, there is no good traction, the car does not drive very dynamically, it drives, but it seems to me that it should go faster with a 3.5 liter engine and 264 horses of power. I suspect the fuel pump is not as good as it was 16 years ago. Any thoughts.
  16. Hello. How often do you need to change the AWD 2008 fuel pump, what is its resource from statistics on statistics?
  17. what tool did you do it with, separately? did you find both parameters and then did the processing and comparison in Excel ? or is it possible to do this cp when searching on google?
  18. I am also interested in this question, but there is little information on it, strangely no one is interested in it.
  19. Buy headlight glass separately for 1.0 2008.Is it possible? I would like to buy headlight glasses for my car, as they are all beaten up with sand and still look good, but not as good as new. There is such a possibility in many other cars, a glass repair kit, but does our generation 1.0 have such a possibility? In addition, I am interested in the opinion of people who installed alternative headlights with two lenses, , if you buy such headlights and install LED lamps in them, perhaps this will be the best solution to improve lighting, who did it? From YouTube videos, it seemed to me that the simple replacement of regular headlights with updated ones with two lenses did not greatly impress the owners, they talked more about the beautiful view, but I need not just a good view, but also good lighting. Who did this, how can the light be improved by 1.0 generation and can I order glasses separately?
