Everything posted by EDST777
Hello. In an adjacent branch I already reported that at me not really well put with my Caliper. To everything it damaged to me from the inside a brake disk. Now I need to change also a brake disk. Time approached to change these parts under the own steam, but my damages gave me pulse (I don't want more than such pulses). Now my brake disks have the following size: damaged 2.5 cm thick (left) and right (not the damaged 2.7 cm). I want to consult to you, whether I can make changeover only of the damaged disk? Or me to change both the left disk and right? Whether my not damaged brake disk, after all there 2.7 cm is so bad. It looks healthy). My second question: what brand of a brake disk to me to select? Now productions Ford (it is made in Europe) and Raybestos are available to me. What from these to me to select two? or there can be you to me advised to buy something another, to make upgrade, how at those sporting guys with red Caliper))? I don't joke, can be there are optimum decisions on upgrade towards improving? Or to leave that that is already set? I ask you your thoughts!
Hi! Simple question. I will change the DOT 4 (DOT3) brake fluid, but in the user's guide volume for full replacement isn't specified, someone knows it? It is 1 liter, 2 liters or how many?) Thanks!
Replacement Front Brake.Original or not?
EDST777 replied to EDST777's topic in Brakes, Chassis & Suspension
o'k -
thanks, I will change brake fluid, I understood it. I also understood that back blocks more important, than and they are more loaded with front. But now I need to understand: whether I need to change back blocks if they are worn-out not rather strongly, by sight they are quite good and wear isn't great? Thanks for your help. -
My front brake shoes need to be replaced. I damaged a slip, it froze today and came off. Blocks were in a good shape, but my odometer shows more than 120 000 km. I think to buy the original Motorcraft, but is it important ?, there can be somebody put forward blocks of other producers (brands RoadHouse, Kashiyama and others) and has experience. I worry for a brake way, our car heavy! Thanks for any thoughts.
Thanks!
friends, unless the rod never broke? )
In addition. Even if the rod is broken why the door isn't fixed in the top situation and falls down? it keeps only a rod, there is no blocking? thanks for any help!
after all what exit to change rods or they can be repaired. Now I have a frost (-21 C) and the back door of a luggage carrier doesn't hold at all when temperature to become higher (-10 with above), then the door starts working. What your thoughts on repair? thanks.
How to Change Speedometer from KPH to MPH
EDST777 replied to bankerjohn's topic in Audio, Backup, Navigation & SYNC
LOL -
Hello! In my 2008 Fords EDGE Limited the system of 6 CDS CHANGER MP3 Player is installed (I attached the image). I quite accept a sound and additional functions: a bluetooth, reading a MP3, AUX, free hands, management from a wheel. Of course, I would wish a touchscreen and navigation, GPS, but it not essentially now, I can does without these functions. I reflected on shipment from China of such device http://ru.aliexpress.com/item/7-Touch-Screen-Special-Car-DVD-for-F150-1999-2000-2001-2002-2003-2004-2005-with/32218952551.html , but then thought as far as it will be better on a sound, what it will give me? Your thoughts about it, such device on a sound and what advantages will be will be how better? Thanks for any thoughts.
Fan scratch behind a glove box at a low temperature.
EDST777 replied to EDST777's topic in Exterior & Body
Thanks! -
Thanks. It is one of ways )) , but strongly expensive. I accept quality and functions of this device so far, I wouldn't want to change it. There are two more ways: 1. To update the software, to a t.a to make software updating (it about what I ask) 2. Installation of the converter from a step 0.2 on a step of 0.1 Mhz is possible, but I don't know where it to buy LOL. Thanks, I after all hope to make updating. Maybe whether someone knows perhaps it on this device?
Hello. I own Edge 2008, at me is established the audio system as on the image. I need to update a FM receiver insertion, what a step of scanning of frequencies of FM to change with (0,2 MHz) the American standard, on European (0,1 MHz). Someone knows as to help with my question? Thanks for any help.
My Edge 2008 limited and in hard frosts-20 C-30 C at start of the engine at me starts whistling the oven fan (the sound follows from a place a glove box of the forward panel, there where the conditioner filter is installed). after warming up of salon the scratch of the fan vanishes. I want to grease the fan. whether it is necessary to remove the forward panel for this purpose? thanks for any help. p.s.:my English not really good but if you didn't understand me, I will specify details. Thanks.
