    272
  1. You have changed the car battery as well as the fob battery?
  2. If everything is otherwise working fine, no warning lights nothing, then go ahead and fill the coolant in the reservoir (with engine cold/at ambient and turned off) to the FULL COLD mark. Then drive around like normal and check again when engine is cold & off. Repeat as needed.
  3. Wouldnt call it failsafe, but it is pretty neat in that only 3 cylinders are fired and the remaining 3 are used as "air coolers". I had asked a tuner about having that as an optional economy mode (cylinder deactivation), but was told it's not a good idea. Anyway, make sure your wife gets a non-3.5. Maybe "3.5" is a jinx LOL.
  4. Ugh, sorry to hear! Dropping in a new engine then? And I wouldn't blame da wife. I think it's just lousy that the design of the water pump makes it near impossible to figure things out until the failure happens. I guess that should be a warning to all of us to change the coolant sooner than the stated 105K miles for the first change. Just not worth the risk.
  5. Be sure to fill up with 50/50 Motorcraft pre-diluted (could be Specialty Green or Specialty Orange, NOT interchangeable) coolant in the reservoir/degas bottle. You may need to top it up a few times depending on how low the coolant actually is. It should burp itself over time, but if it doesn't and you have temperature control problems, you will need to follow a "burp"ing procedure at that time. How frequently do you check the coolant? Was this the first time?
  6. I am thinking cracked tube/housing, but I dont know why the oil is turning "milky". Are you sure the oil is simply not breaking down, possibly because the oil level is low?
  7. The video should be uploaded to a sharing site like flickr, photobucket, etc then linked back here. How many miles on your MKX? "water" coming out, meaning coolant, right? From the location, it is likely a cracked block OR the coolant xover tube OR the thermostat housing that gave way. I hate to say this, but regardless of the cause (water pump, head gasket, cracked block), you may want to look at getting a low mileage used engine and having that put in instead of attempting repairs. At least figure out if that option is viable for you or not.
  8. I would take a wild guess and say minimal, not knowing which bolt we are talking about. I think the long bolts (there are 2 of them) are probably more important.
  9. The bolts are purchasable individually. Probably broken or the thread is stripped. Hopefully it's just broken, then you can take off the intake and retrieve the bottom half with a pliers or similar tool. You may need to PB Blaster it after covering up the intake ports to get it to come out. http://www.fordpartsgiant.com/parts-list/2012-ford-edge/intake-manifold.html?Filter=(30393) Which bolt in particular is the issue, can you identify it in a pic?
  10. I second duct tape LOL. Or nail polish plastidip is too easy.
  11. Very possibly a TSS/OSS sensor issue. Always replace in pairs.
  12. Simple things make the biggest difference And you realizing and adjusting accordingly
  13. You can upgrade to specialty green, BUT green and gold are NOT compatible. So you have to flush out the gold antifreeze completely prior to putting in any green antifreeze.
  14. Sounds great already, clean letoff, not like those cheap bass speakers that fumble everything
  15. Should the above ideas not work out ... It is possible the valve body is sticking just a tad and pressures aren't high enough at low throttle to overcome it. It'd be worth doing a 3x drain & fill of the fluid regardless, with unknown history. No flushes.
  16. Overly Sensitive Brake Application At Low Speed And/Or In Cold/Wet Conditions – 2015-2016 Ford Edge & 2016 Lincoln MKX oemdtc June 2, 2016 Diagnostic Tips 2015-2016 Edge And 2016 Lincoln MKX – Overly Sensitive Brake Application At Low Speed And/Or In Cold/Wet Conditions – Built On Or Before 3/23/2016 Some 2015-2016 Edge and 2016 Lincoln MKX vehicles built on or before 3/23/2016 may exhibit overly sensitive brake applications. This will typically occur at low speed and/or in cold/wet conditions. To correct the condition, install an updated brake booster with part number F2GZ-2005-F (only 2.0L GTDI with 17” rotors) or F2GZ-2005-E (all except 2.0L GTDI with 17” rotors). PART NUMBER PART NAME F2GZ-2005-F Brake Booster 2.0L GTDI with 17” Rotors F2GZ-2005-E All Except 2.0L GTDI with 17” Rotors Refer to Workshop Manual, Section 206-07.
  17. Passenger Side Halfshaft Seal Leak – 2013-2017 Ford & Lincoln oemdtc July 26, 2016 Info 2013-2017 Fusion/Escape/MKZ, 2015-2016 Edge/Explorer/MKC, And 2016 MKX – Passenger Side Halfshaft Seal Leak – PTU Bushing Now Available For AWD Vehicles 2013-2017 Fusion/Escape/MKZ (excluding 3.7L), 2015-2016 Edge/Explorer (excluding 3.5L/3.7L), 2015-2016 MKC, and 2016 MKX vehicles (excluding 3.7L) equipped with All Wheel Drive (AWD) may exhibit a leaking passenger side power transfer unit (PTU) halfshaft/linkshaft seal. This may be due to a worn PTU bushing. The PTU bushing can now be repaired without PTU replacement. The online WSM is being updated for all listed vehicles.Refer to the intermediate shaft bushing removal and installation in Workshop Manual (WSM), Section 308-07. The procedure is the same for all vehicles. If the procedure is not published for the vehicle being serviced check the WSM of another listed vehicle. Bushing part number is F2GZ-63600A58-A. The parts catalog is being updated to include this bushing. Part Number Part Description F2GZ-63600A58-A Bushing
  18. Noise From Cooling Fans – 2015-2016 Ford Edge & 2016 Lincoln MKX oemdtc July 26, 2016 Repair Tips 2015-2016 Edge And 2016 MKX – Noise From Cooling Fans – Built On Or Before 6/11/2016 Some 2015-2016 Edge and 2016 MKX vehicles built on or before 6/11/2016 may exhibit a noise from the electric cooling fans, most noticeable right after the engine is turned off as they spin down to a stop. If the noise can be pinpointed to the cooling fan motor, install a new cooling fan motor and shroud F2GZ-8C607-E which was released for service to resolve this concern. Part Description Part Number Cooling Fan Motor and Shroud F2GZ-8C607-E
  19. Intermittent Park Aid Sensor Fault Message Or Ambient Air Temperature (AAT) Incorrect – 2015-2016 Ford Edge & 2016 Lincoln MKX oemdtc September 5, 2016 2015-2016 Edge – 2016 MKX – Intermittent Park Aid Sensor Fault Message Or Ambient Air Temperature (AAT) Incorrect With Or Without Inoperative A/C Some 2015-2016 Edge and 2016 MKX vehicles may exhibit an intermittent park aid sensor fault message illuminated in the instrument panel cluster (IPC) message center or an AAT that intermittently reads incorrectly with or without inoperative air conditioning (A/C). If water intrusion is found in wiring connector C140, service pigtails EU2Z-14S411-VA (male) and CU2Z-14S411-ADA (female) have been released. Replacement of wiring harness 15K867 (male) or 14K733 (female) is no longer necessary when either of these connectors require servicing. Service Pigtail (Male) EU2Z-14S411-VA Service Pigtail (Female) CU2Z-14S411-ADA
  20. As requested 2011 Edge 3-5L Engine Removal & Installation.pdf
  21. ever changed plugs/pcv valve/coils? Those would be my first attempt to address the issue.
