Sweet! -
Welcome and Congrats!!!
Welcome!
Both the Michelin Premier and Defender will work well for you. The Defender is longer lasting but the Premier is no slouch.
Welcome! How much mileage on your Edge? Makes me suspect the solenoid body. It can be checked without any disassembly required. If the electrical values are near the limits of allowable specs, replace it along with the solenoid body filter. A simpler item could be the torque mount/dogbone. easy to check, a little harder to replace on AWD, but 2 hrs shop labor or DIY if you are handy.
Given the driving scene these days, not surprised. Those drivers may have been perfect the rest of the drive, and just got tuckered out for that moment. Following their journey and talking to them is the only way to know. Also if there is a way to easily blot out license plates, please do it.
Congrats, let's see some pics!
Year and mileage? Are you sure timing is not a tooth off? Did you replace the VCT solenoids also? Might need the phasers if the TSB applies. TSB 11-6-1_3.5L-3.7L ENGINE - VCT CODES P0011, P0012, P0016, P0018, P0021, P0022 - RUNS ROUGH OR MISSES - VEHICLES BUILT ON OR BEFORE 20081215.pdf
Congrats, hope pregnancy and delivery go super smooooooth! Did you go for the max size available -
Buy the ford plug/coil/gasket kit. under 180 shipped. BA5Z-12259-A Injectors no real deals, RockAuto has the best prices. Bosch and OEM are preferred https://www.rockauto.com/en/catalog/ford,2007,edge,3.5l+v6,1434490,fuel+&+air,fuel+injector,6224
Gen 2 Edge Rear Camber & Toe Adjustments
WWWPerfA_ZN0W replied to connoisseurr's topic in Brakes, Chassis & Suspension
TOE https://drive.google.com/open?id=1fR395300EP1PTYpzxLY_82-M2Mp4_rcz CAMBER https://drive.google.com/open?id=1GC3gUe153zzVZopAf1OnCgtismoGfTiN -
get more life out of them. bank 1 (firewall side) coils are in a heat intensive environment with comparatively low airflow. So if all the coils are good, put the ones that have faced less challenges on the back, and the back ones on the front.
I think it is worth it do so yes. And at least rotate the coils front to back/back to front if not replacing them entirely. 2007 & 2008 were problematic years with coils/PCM going bad from worn plugs.
Just Bought Our New (old) 2013 Edge Sport in Tuxedo Black
WWWPerfA_ZN0W replied to Bradley Young's topic in Welcome Forum!
Welcome, and enjoy!- 5 replies
- edge sport
- 2013 ford edge sport
- (and 3 more)
Cool info on the ST! Pics of your new ride when you get a moment
you sir are absolutely correct! In any case, seems to be a fair bit of annual mileage on the vehicle, so you would not think typical severe operating conditions type issues. But never hurts to start with looking at the plugs, as they tell the story of what is happening inside the engine.
Firing order is defined in terms of cylinder #, not the other way round. Cylinder numbering is 1 2 3 4 as you look from left to right (pass side to driver side of the engine). On an ecoboost, could be a spark plug or fuel injector. If plug is bad, replace them all. You have not stated mileage on your 2017 ...
Mileage on your edge? Maintenance history including plugs/coils/pcv valve? could be misfiring, in which case the CEL should flash.
how many miles on your Edge? have the plugs/coils/pcv valve been serviced yet? could be bad fuel or sticking injector(s). if this just started happening, check to see if a changeover to winter fuel has occurred in your area. run a bottle of HEET (yellow) thru the tank, see if that helps. does the CEL flash at any time during this event?
The forum software is downsizing any "enlarged" pics unfortunately. You will want to open the pic in a separate window/tab (or save/open it) and manually zoom in.
Super Grabby Brakes - 2016 - Build 31-May-2016
WWWPerfA_ZN0W replied to evh's topic in Brakes, Chassis & Suspension
Have you approached more than one dealer about this? Worked up the ladder at the dealership? Tried a Lincoln dealership? Talked to Ford Corporate directly? Sometimes you can grab Ford's attention on Twitter @FordService (if that handle is still active).
