Haz
    436
Everything posted by Haz
  1. Welcome to the Forum, Anthony_a2 ! Diagnostic Trouble Codes (DTCs) may be present that can guide corrective efforts. Try performing the Audio Control Module (ACM) Self-Diagnostic procedure, also known as Bezel Diagnostics. From the 2010 Edge Workshop Manual... Audio Systems With Navigation Turn the ACM on. Operate the audio system in radio tuner (AM/FM) mode. Press and hold preset buttons 3 and 6 for 3 seconds until the speaker walk test begins. The display indicates each speaker as it is tested. NOTE: If the speaker walk test is the only test required, this procedure can be stopped after this step, or by allowing the speaker walk test to complete on its own. Before the speaker walk test is complete, press the "End Test" selection. The following tests are available through the "BEZEL DIAGNOSTICS" menu: Display Selection Diagnostic Function Description On Demand Self Test The ACM carries out a self-test. At the end of the self-test, the display either indicates "Test Passed" or lists any DTCs present. Note that the self-test may not indicate all DTCs that are present. If DTCs are suspected, retrieve continuous and on-demand DTCs using the scan tool. View DTCs The ACM displays any DTCs that are present. If there is more than a full screen of DTCs present, to scroll through the DTCs, press the down arrow on the display. If no DTCs are present, the display reads NO DTCS. Press the "Clear DTCs" selection to clear any DTCs present. Configuration Status The display shows the ACM configuration. A "0" indicates the item is configured off, while a "1" indicates the item is configured on. If the ACM appears to be misconfigured, refer to Section 418-01. System Info The ACM displays system information for various components of the audio system. The following items are most important for servicing the audio system: Nav Radio Part Number — provides the ACM part number ESN1 — provides the satellite radio Electronic Serial Number (ESN) GPS Info The current Global Positioning System (GPS) satellite information is shown, along with the current vehicle position. Pressing the "SV Status" selection provides additional information, if present. Speaker Walk Test The ACM carries out the speaker walk test. DVD Mechanism Test The ACM tests the internal CD/DVD drive mechanism. Display Test This test provides for testing of the touchscreen colors and the touchscreen sectors. Pressing any of the colors on the display causes the whole display to change to that color; pressing the display again returns to the Display Test menu. Pressing the "Touchscreen Activation Test" selection enters the touchscreen sector test. Press any area of the screen to test the touchscreen sector; press the "X" at the RH lower corner of the display to return to the Display Test menu. Hardkey Test This test provides for testing of the ACM buttons (not the touchscreen). When each button is pressed, the screen displays the button that is active. This test can also be used to isolate a stuck button. Radio Signal Strength The ACM displays the AM/FM antenna signal strength. To run this test, the audio system should be in AM radio tuner mode before entering the ACM self-diagnostic mode. HDD Test The ACM tests its internal hard drive. Sensor I/O Status The ACM displays inputs it is receiving from external sources. These inputs include: Ignition — indicates ON (ignition in ACC or RUN) or OFF Brake — indicates ON (brake applied) or OFF (brake not applied) Illumination — indicates ON or OFF ReverseGear — indicates ON (vehicle in reverse) or OFF (vehicle not in reverse) Microphone Test The ACM tests the microphone by supplying a test tone and monitoring the input from the microphone. As this vehicle is not equipped with a microphone, this test does not provide any diagnostic assistance. SDARS Signal Strength The ACM displays the satellite radio antenna signal strength. To exit the self-diagnostic mode, press the "Exit Diagnostics" selection from the "BEZEL DIAGNOSTICS" menu. Please report back on the outcome, and then we'll determine if additional diagnostic procedures are necessary. Good luck!
  2. The audio system not powering-off via spoken SYNC command is an added symptom that dealership Service staff will explore, along with any related DTCs, if they exist. The issue may involve corrupted software or a faulty module, apart from the audio control panel. Online resources show your Edge's various SYNC & APIM software are up-to-date, but the dealership tech will connect your Edge to Ford's online Service systems to verify that, as well as to perform other diagnostic procedures comparable to Pinpoint Test J. Establishing a relationship with a local dealer's Service department is a useful thing, especially if they participate in Ford's Pickup & Delivery Service. As MLTEdge describes, absent overt physical damage, correcting this issue will very likely occur at no cost to you. I can't speak to the Power pushbutton's depth of travel, if it is other-than a momentary contact control -- perhaps another GEN 2 Edge owner will clarify that. Good luck!
  3. First released in December 2006, this instructive reference for Service Advisors and Technicians provides photos of tire conditions & guidance on whether they are warrantable or unwarrantable... Document download link> Tire Warranty Conditions Guide - 12-01-2006.pdf
  4. Based upon this description from the 2013 Edge Workshop Manual... Steering Wheel Controls The steering wheel controls are mounted directly to the steering wheel and wired to the Steering Column Control Module (SCCM) . Depending on what features the vehicle is equipped with, the SCCM sends messages via the High Speed Controller Area Network (HS-CAN) to the PCM (cruise control) and the Instrument Panel Cluster (IPC) (message center and entertainment system). The IPC receives the SCCM entertainment system messages via the HS-CAN and then sends them to the applicable entertainment system module(s) along the Infotainment Controller Area Network (I-CAN) . ...and this Front Control/Display Interface Module (FCDIM) - wiring diagram... Your Edge's main plug may be the FCDIM Connector C2123... If so, then your Aftermarket Head's two wires may find their rightful places on Pin 4 and Pin 5... Document download links> FRONT CONTROL DISPLAY INTERFACE MODULE (FCDIM) - Wiring Diagram - 2018 Edge.pdf FRONT CONTROL DISPLAY INTERFACE MODULE (FCDIM) - Connector C2123 Location - 2018 Edge.pdf FRONT CONTROL DISPLAY INTERFACE MODULE (FCDIM) - Connector C2123 Details - 2018 Edge.pdf Steering Wheel Switch, Right - Wiring Diagram without SYNC - 2013 Edge.pdf Steering Wheel Switch, Right - Connector C2999 Location - 2013 Edge.pdf Steering Wheel Switch, Right - Connector C2999 Details - 2013 Edge.pdf Good luck!
  5. Additional document download links> Charging System - 2.0L EcoBoost - Diagnosis and Testing - 2018 Edge Workshop Manual.pdf Pinpoint Test AJ - THE CHARGING SYSTEM RTT WARNING INDICATOR IS NEVER OR ALWAYS ON - 2018 Edge Workshop Manual.pdf Good luck!
  6. Relating to the Battery Monitoring System (BMS) reset method and effects, this from the 2018 Edge Workshop Manual... If the vehicle battery is replaced, it is very important to perform the BMS Reset using a diagnostic scan tool. This reset is reserved for new battery installation. Resetting the battery monitoring system will clear the learned battery data, the battery time in service, and will affect the aging algorithm parameters, which have been learned since the installation of the battery. If the battery monitoring system reset is not carried out, it holds the old battery parameters and time in service counter in memory. Additionally it tells the system the battery is in an aged state and may limit the Electrical Energy Management system functions. So, use of a diagnostic scan tool (including Forscan and other scanning apps) is the only way to perform a BMS reset. The 8-hours is involved in the Body Control Module (BCM) validly tracking the battery's State of Charge, this from the 2018 Edge Workshop Manual... The BCM uses the battery current sensor (without auto-start-stop) or battery monitoring sensor (with auto-start-stop) to keep track of the battery state of charge. During a drive cycle the Electrical Energy Management software adjusts the battery state of charge up during charging, and down during discharge. During rest periods with the key off, and the vehicle enters sleep mode, the BCM automatically recalibrates the Battery State of Charge. It takes 8 hours in sleep mode, with the vehicle undisturbed, no doors opened or keyless entry buttons pressed, and the total vehicle current draw less than 300mA, to calibrate the battery state of charge to a high accuracy. If the system draw has not allowed the battery state of charge to calibrate over the previous 7 days, the state of charge quality factor changes to identify this and some Electrical Energy Management system functions may be temporarily turned off until a calibration takes place. This vehicle is equipped with an Electrical Energy Management system which manages battery charging and monitors the battery state of charge. The Electrical Energy Management system software is housed in the BCM . It has the algorithms and control structure for the Smart Regenerative Charging, and Load Shed Control Strategy. The Electrical Energy Management system is equipped with a battery current sensor (without auto-start-stop), or a battery monitoring sensor (with auto-start-stop) and generator current sensor to monitor the battery. These sensors serve as input to the Electrical Energy Management system software. If the sensors malfunction due to wiring issues or failure, a DTC will be set. In most cases the Electrical Energy Management system functions will be turned off until the sensor operation is restored. So, while the 8-hours in sleep mode doesn't perform a BMS reset, it is comparably important. Relating to the CHECK CHARGING SYSTEM message and/or the charging system warning indicator, this from the 2018 Edge Workshop Manual... The PCM reports any charging system faults and sends a message through the High Speed Controller Area Network (HS-CAN) to the BCM . The BCM controls the charging system warning indicator by sending a message over the Medium Speed Controller Area Network (MS-CAN) to the IPC . The IPC then controls charging system warning indication based on the message from the PCM through the BCM . The status of the PCM charging system warning indicator and/or message is confirmed by viewing PCM PID generator fault indicator lamp (GENFIL). Any charging system fault detected by the PCM results in 1 or more Diagnostic Trouble Codes (DTCs) being set and the PID GENFIL having a status of On. If equipped with a charging system warning indicator, the IPC turns the indicator on or off. If equipped with a message center, the IPC displays a CHECK CHARGING SYSTEM message. In some instances, the CHECK CHARGING SYSTEM message may not display if the ignition is on and the engine is off. Under certain circumstances, the charging system may have a concern but will still keep the battery charged and the vehicle running. GENCOM normally initiates charging but with a fault in this circuit, the generator can self-excite and start charging on its own. The charging system warning indicator is illuminated and/or the CHECK CHARGING SYSTEM message is displayed, and the generator operates in a default mode (approximately 13.5 volts). The Charging System RTT Warning Indicator Is Never Or Always On Normal Operation and Fault Conditions See Charging System RTT indicator. REFER to: Message Center - System Operation and Component Description (413-01 Instrumentation, Message Center and Warning Chimes, Description and Operation). If the charging system indication request is missing for less than 5 seconds, the IPC defaults the charging system RTT indicator to the last indication state (on or off), based upon on the last message received. If the charging system indication request is missing for 5 seconds or longer, the IPC defaults the charging system RTT indicator on. Possible Sources Charging system concern Communication concern GWM concern IPC PINPOINT TEST AJ: THE CHARGING SYSTEM RTT (RECONFIGURABLE TELLTALE) WARNING INDICATOR IS NEVER OR ALWAYS ON AJ1 CHECK THE MESSAGE CENTER OPERATION Ignition ON. Close all doors, the hood and the liftgate. Clear all message center warnings by pressing the OK button for each warning present. Monitor the door ajar RTT warning indicator. Open the driver door. Clear the message center popup warning. Monitor the door ajar RTT warning indicator. Is the door ajar RTT warning indicator off with the door closed, and on with the door open? Yes GO to AJ2 No VIN required to access Guided Routine (IPC) AJ2 PERFORM THE IPC (INSTRUMENT PANEL CLUSTER) SELF-TEST Using a diagnostic scan tool, perform the IPC self-test. Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to DTC Chart: IPC in this section. No GO to AJ3 AJ3 CHECK THE GWM (GATEWAY MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS) Using a diagnostic scan tool, check the GWM Continuous Memory Diagnostic Trouble Codes (DTCs). Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing). No GO to AJ4 AJ4 CHECK THE CHARGING SYSTEM OPERATION Check the charging system operation. Does the charging system operate correctly? Yes If the charging system warning indicator is never on, the system is operating correctly at this time. If the charging system warning indicator is always on, DIAGNOSE all BCM Diagnostic Trouble Codes (DTCs). REFER to: Body Control Module (BCM) (419-10 Multifunction Electronic Modules, Diagnosis and Testing). No REFER to: Charging System - 2.0L EcoBoost (184kW/250PS) – MI4 (414-00 Charging System - General Information, Diagnosis and Testing). Relevant sections of the 2018 Edge Workshop Manual are linked for download below, and in an immediately following post, due to Forum file attachment limitations... Document download links> Charging System - 2.0L EcoBoost - Overview - 2018 Edge Workshop Manual.pdf Charging_System_-_2.0L_EcoBoost_-_System_Operation_and_Component_Description_-_2018_Edge_Workshop_Manual.pdf Message Center - System Operation and Component Description - 2018 Edge Workshop Manual.pdf Battery Load Shed - Description and Operation - 2018 Edge Workshop Manual.pdf
  7. SSM 52206 - 2024 Lincoln Nautilus - Reserve And Black Label - Knocking Type Noise From Rear Shock Absorber Area Some 2024 Lincoln Nautilus vehicles equipped with the Reserve and Black Label packages may exhibit a knocking noise from the rear shock absorber area of the vehicle while driving at speeds between 8 mph and 19 mph (13 km/h and 30 km/h) on rough road surfaces or when going over bumps. If the concern is isolated to the rear shock absorber assembly, replacing it at this time is unlikely to resolve the concern and is not recommended. This concern has no effect on vehicle operation or durability and is currently under investigation. Repair direction is expected late Q1 2024. Schedule a service appointment for this timeframe and monitor OASIS for additional information.
  8. Document download link> Bezel Diagnostics - General Procedures - 2022-2024 Edge Workshop Manual.pdf Good luck!
  9. It is true that scanning your Edge's electronic modules will reveal any current and/or historical DTCs, including those associated with the Audio Control Panel. Your good choice to invest in the longer-term Ford Protect CPO-Wraparound Premiumcare, to expand the covered items and extend the duration of the selling dealership's Blue Advantage Gold CPO, relieves you of any need to scan the Edge, unless you already have the device on hand. The selling dealer's Service department will surely correct your Edge's radio power-off issue, and your being able to tell them whether or not the radio powers-off to your SYNC Voice Command may be useful to the Service Writer and Repair Tech as they seek the issue's root cause. Your Edge's original factory Bumper-To-Bumper warranty coverage expires on August 13, 2024, so covered Warranty repairs to your vehicle should be performed at no cost to you through that date. After that, the $100 deductible of your Ford Protect CPO-Wraparound contract will apply to covered repairs, except in the case of manufacturer Recall actions which are fulfilled at no cost to owners. There are no unfulfilled Field Service Actions on your Edge, as a result of the selling dealer's completion of Recall 22S14 (link to details) in November 2023. Once again, welcome to the Forum -- and congratulations on your 2021 Edge/CPO-wraparound purchase. Good luck!
  10. Document download link> Headlamp Assembly - Removal and Installation - 2022-24 Edge Workshop Manual.pdf Good luck!
  11. Providing full removal procedure with fastener locations for possible partial unfastening & repositioning to accomplish your task. Document download link> Fender Splash Shield - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Good luck!
  12. I surveyed photos of 2021-2023 Edges offered for sale online and these images are representative of what I found... The Edge Workshop Manual offers 'Pinpoint Test J' as a diagnostic for the Audio Control Panel. Diagnostic Trouble Codes (DTCs) which are set for several faulty conditions... The DTCs for knob control fault and/or continuous button press may indicate an issue with the Power Button. Given that the sales rep unsuccessfully addressed the radio power-off question with you, and, you've recognized the no-power-off issue after only two weeks, the selling dealer may consider covering the full repair cost or a shared-cost repair arrangement for your Edge. Have you tried using SYNC Voice Command to turn off the radio? If the dealer refuses to cover any repair cost, and using SYNC Voice Command successfully turns radio power Off and On, then it's up to you to decide if the cost of a functioning Power button is worth it. Additional Workshop Manual documents relating to the Audio Control Panel are attached for your awareness... Document download links> PINPOINT TEST J - THE AUDIO-SYNC SYSTEM DOES NOT OPERATE CORRECTLY FROM THE AUDIO CONTROL PANEL - 2021 Edge.pdf Audio Control Panel to SYNC Module Wiring Diagram - 2021 Edge.pdf AUDIO CONTROL PANEL - Connector C2009 Details - 2021 Edge.pdf AUDIO CONTROL PANEL - Connector C2009 Location - 2021 Edge.pdf SYNC MODULE (APIM) - Connector C2383A Details - 2021 Edge.pdf SYNC MODULE (APIM) - Connector C2383A Location - 2021 Edge.pdf Audio Control Panel to Body Control Module (BCM) Wiring Diagram - 2021 Edge.pdf Audio Control Panel to Ground Wiring Diagram - 2021 Edge.pdf Audio Control Panel to HVAC Module Wiring Diagram - 2021 Edge.pdf Audio Control Panel to Body Control Module (BCM) Hazard Lamps Wiring Diagram - 2021 Edge.pdf Good luck!
  13. Additional info... 2019-2024 Edge Workshop Manuals all include the Sport Mode Traction Control engage/disengage instruction, along with a typo omitting the word spirited. Placing your device cursor over underlined acronyms may yield full-word descriptions... AdvanceTrac The AdvanceTrac system is comprised of the traction control and ESC features. Traction Control (TC) The ABS module continuously monitors and compares the rotational speed of the drive wheels in relation to the non-driven wheels. When the drive wheels begin to spin faster than the non-driven wheels, the ABS module modulates brake pressure to the appropriate brake caliper(s) by opening and closing the appropriate solenoid valves inside the HCU while the hydraulic pump motor is activated. At the same time, the ABS module calculates how much engine torque reduction is required to eliminate the wheel slip and sends this torque reduction message along with a traction event message to the GWM over the HS-CAN2 . The GWM sends the engine torque reduction message to the PCM over the HS-CAN1 and the traction event message to the IPC over the HS-CAN3 . When the PCM receives the torque reduction message, it adjusts engine timing and decreases fuel injector pulses to reduce the engine torque to the requested level. When the IPC receives the traction event message it flashes the stability-traction control indicator (sliding car icon). Once the driven wheel speed returns to the desired speed, the ABS module returns the solenoid valves in the HCU to their normal position, deactivates the hydraulic pump motor and stops sending the traction event and torque reduction messages. The PCM returns engine timing and fuel injectors to normal operation and the IPC extinguishes the stability-traction control indicator (sliding car icon). After the vehicle speed exceeds 100 km/h (62 mph), traction control is accomplished only through the PCM torque control. Traction control can be disabled using the traction control switch in the following manner: Momentarily pressing the switch disables only traction control, ABS , ESC and RSC remain enabled. Pressing the switch twice rapidly engages Sport Mode. Sport mode modifies the stability control intervention thresholds to allow for a more driving experience. Pressing the switch once after the system is deactivated fully enables the traction control system. Pressing the switch once after Sport mode is activated, deactivates Sport mode and fully enables the traction control system. When the driver disables traction control, the IPC communicates traction control status to the GWM along the HS-CAN2 . The GWM sends the message to the ABS module along the HS-CAN2 . The ABS module takes no further action in regards to traction control until the driver activates the function or until the ignition is cycled from OFF to ON. Traction control is disabled if there is a wheel speed sensor or solenoid valve DTC present in the ABS module. Traction control is also disabled if there is a communication error between the ABS module and the GWM . When traction control is disabled, the ABS module sends a message to the GWM along the HS-CAN2 which gateways the message to the IPC over the HS-CAN3 to illuminate the stability-traction control OFF indicator (sliding car OFF icon). Electronic Stability Control (ESC) The ABS module continuously monitors the vehicle motion relative to the intended course. This is done by using sensors to compare the steering wheel sensor messages, yaw rate sensor messages and longitudinal acceleration with the actual vehicle motion. On vehicles without active park assist, steering angle information is calculated by the PSCM and sent to the ABS module over the HS-CAN2 . On vehicles with active park assist, steering angle information is sent by the SCCM over the HS-CAN2 . Vehicle yaw rate and longitudinal acceleration information is sent to the ABS module from the RCM over the HS-CAN2 . If the ABS module determines from the inputs the vehicle is unable to travel in the intended direction, the brake pressure to the appropriate brake caliper(s) is modulated by opening and closing the appropriate solenoid valves inside the HCU while the hydraulic pump motor is activated. At the same time the ABS module calculates how much engine torque reduction is required to reduce vehicle speed to help stabilize the vehicle and sends this torque reduction message, along with an ESC event message, to the GWM over the HS-CAN2 . The GWM sends the torque reduction message to the PCM over the HS-CAN1 and the ESC event message to the IPC over the HS-CAN3 . When the PCM receives the torque reduction message, it adjusts engine timing and decreases fuel injector pulses to reduce the engine torque to the requested level. When the IPC receives this message, it flashes the stability-traction control indicator (sliding car icon). Once the vehicle instability has been corrected, the ABS module returns the solenoid valves in the HCU to their normal position, deactivates the hydraulic pump motor and stops sending the ESC event and torque reduction messages. The PCM returns engine timing and fuel injectors to normal operation and the IPC extinguishes the stability-traction control indicator (sliding car icon). ESC does not operate with the transmission in REVERSE. ESC is disabled if there is a wheel speed sensor, stability sensor or steering angle sensor DTC present in the ABS module. ESC is also disabled if there is a communication error between the ABS module and the PSCM , the ABS module and the RCM or the ABS module and the SCCM (if equipped). When ESC is disabled, the ABS module sends a message to the GWM along the HS-CAN2 which gateways the message to the IPC over the along the HS-CAN3 to illuminate the stability-traction control OFF indicator (sliding car OFF icon). Roll Stability Control (RSC) The ABS module continuously monitors the vehicle motion relative to the intended course. This is done by using sensors to compare the steering wheel sensor messages, yaw rate sensor messages, lateral acceleration sensor messages, longitudinal acceleration sensor messages and roll rate sensor messages with the actual vehicle motion. On vehicles without active park assist, steering angle information is calculated by the PSCM and sent to the ABS module over the HS-CAN2 . On vehicles with active park assist, steering angle information is sent by the SCCM over the HS-CAN2 . Vehicle yaw rate, lateral acceleration, longitudinal acceleration and roll rate information is sent to the ABS module from the RCM over the HS-CAN2 . If the ABS module determines from the inputs the vehicle is becoming unstable, the brake pressure to the appropriate brake caliper(s) is modulated by opening and closing the appropriate solenoid valves inside the HCU while the hydraulic pump motor is activated. At the same time the ABS module calculates how much engine torque reduction is required to help stabilize the vehicle and sends this torque reduction message, along with an RSC event message, to the GWM over the HS-CAN2 . The GWM sends the torque reduction message to the PCM over the HS-CAN1 and the RSC event message to the IPC over the HS-CAN3 . When the PCM receives the torque reduction message, it adjusts engine timing and decreases fuel injector pulses to reduce the engine torque to the requested level. When the IPC receives this message, it flashes the stability-traction control indicator (sliding car icon). Once the vehicle instability has been corrected, the ABS module returns the solenoid valves in the HCU to their normal position, deactivates the hydraulic pump motor and stops sending the RSC event and torque reduction messages. The PCM returns engine timing and fuel injectors to normal operation and the IPC extinguishes the stability-traction control indicator (sliding car icon). RSC does not operate with the transmission in REVERSE. RSC is disabled if there is a wheel speed sensor, stability sensor or steering angle sensor DTC present in the ABS module. RSC is also disabled if there is a communication error between the ABS module and the PSCM , the ABS module and the RCM or the ABS module and the SCCM (if equipped). When RSC is disabled, the ABS module sends a message to the GWM along the HS-CAN2 which gateways the message to the IPC over the along the HS-CAN3 to illuminate the stability-traction control OFF indicator (sliding car OFF icon). Ford's advice to not use Sport Mode may be due to the outcome of a driver losing control of a vehicle having diminished TC/ESC reactive capability on public roads, compared to the same event occurring on a race track. Good luck!
  14. Document download links> Generator - 2.7L EcoBoost - Removal and Installation - 2016 Edge Workshop Manual.pdf Air Conditioning Compressor - 2.7L EcoBoost - Removal and Installation - 2016 Edge Workshop Manual.pdf Please note that several of the numbered action-step descriptions appear on the page prior to the illustration to which they apply, due to formatting for maximum illustration size. Go Vols !
  15. Welcome to the Forum, Termin8r ! As others have mentioned, from the 2021 Edge Owner's Manual... If the power switch function of the left control knob is faulty, the Radio Control Switch Panel is replaceable separate from the Display Screen... Document download links> Audio Controls - Removal and Installation - 2021 Edge Workshop Manual.pdf Floor Console - Removal and Installation - 2021 Edge Workshop Manual.pdf Good luck!
  16. From the 2012 Edge Workshop Manual... Battery Management System Load Shed Strategy NOTICE: When any vehicle module is being programmed, connect an external battery charger to make sure that the module programming is completed without the interruption due to the load shedding feature becoming active. The external battery charger must maintain a system voltage above 13 volts. This can require a charger setting higher than the lowest charge setting. The external battery charger negative connection must be made to an engine or vehicle chassis ground and not the negative battery terminal. If the connection is to the negative battery terminal, load shedding cannot be prevented from being invoked and module programming may be corrupted. After charging has begun, start the engine to clear any load shed states and then turn the engine off and proceed with programming. NOTE: To maintain correct operation of the load shed, any electrical devices or equipment must be grounded to the chassis ground and not the negative battery terminal. A connection to the negative battery terminal can cause an inaccurate measurement of the battery state of charge and can cause incorrect load shed system operation. This vehicle is equipped with a load shed strategy. The Body Control Module (BCM) uses the battery current sensor to keep track of the battery state of charge. The battery current sensor is a Hall-effect sensor attached to the battery ground cable. On vehicles equipped with Intelligent Access (IA) , the ignition state can also change. Engine Off Load Shed The BCM uses the battery current sensor to keep track of the battery state of charge. The battery current sensor is a Hall-effect sensor attached to the battery ground cable. When the engine is off, and the BCM determines the battery state of charge is below 40%, 10% of the charge has been drained or 45 minutes have elapsed, a load shed message is sent over the Controller Area Network (CAN) . This message turns off the audio system to save the remaining battery charge. Under this condition, a message may be displayed on the IPC or center stack display to alert the driver that battery protection actions are active. When charging the vehicle battery by connecting the charger to the negative battery terminal is necessary, such as when using a combination battery charger and battery tester/analyzer, like the GR 1 190 V3.0 Intelligent Diagnostic Charger, the BCM will not immediately update the battery state of charge. In this instance, after charging, you must CARRY OUT the Battery Monitoring System (BMS) Reset using the scan tool. This reset is needed for proper engine off load shedding and to prevent invoking of engine off load shedding earlier than normal. NOTE: If the reset is not carried out, when the battery is charged by connecting the charger to the negative battery terminal, it takes approximately 8 hours for the BCM to learn the new battery state of charge. During this 8 hour period, the vehicle must be undisturbed, with no doors opened or keyless entry button presses. If the vehicle is used before the BCM is allowed to learn the new battery state of charge, engine off load shedding can still occur and a message may be displayed. When charging the vehicle battery by connecting the charger to engine or chassis ground, the negative charger clamp must be connected to an unpainted chassis surface or a solid engine component such as a generator mount or engine lifting eye. In this instance, after charging, the BMS reset is not required if the ignition was ON during charging by above method. Through this method of charging, the BCM updates the battery state of charge during the charging process. If the ignition was OFF during charging by above method, a BMS reset may be required since the BCM does not update battery state of charge with ignition key OFF unless the vehicle is parked undisturbed for 8 hours. Document download link> Charging System - Diagnosis and Testing - 2012 Edge-MKX Workshop Manual.pdf Good luck!
  17. This topic is being recommunicated as Special Service Message 52172, highlighting the 2024 Nautilus owner's ability to recover the Master Access Code, due to the absence of a keypad code card being provided with the vehicle at delivery... SSM 52172 2024 Nautilus - Keyless Entry Keypad Code Card Missing Some 2024 Nautilus vehicles may incorrectly list the keyless entry keypad code card on the loose item checklist. 2024 Nautilus vehicles in North America do not include keyless entry keypad code cards. Clients are now able to retrieve the vehicle's keyless entry keypad master access code in vehicle by following the instructions in the Owner's Manual > Keyless Entry Keypad Master Access Code. This process requires the use of two programmed intelligent access keys.
  18. CARR142: Saddened to learn of your MKX's fate, but more fully saddened over you being stolen away from all of us. Please let us know what you replace the MKX with. Good luck! From https://www.nicb.org/vincheck
  19. THIS GSB 23-7173 HAS BEEN SUPRECEDED BY GENERAL SERVICE BULLETIN 24-7133, WHICH IMMEDIATELY FOLLOWS... GENERAL SERVICE BULLETIN Various Vehicles - Rear-View Mirror Concern Analysis 23-7173 05 January 2024 This bulletin supersedes 23-7092. Summary This article supersedes GSB 23-7092 to add the Melted Housing section and update the power mirror synchronization. This article is designed to provide examples of interior and exterior rear-view mirror conditions/damage to assist in determining if the condition is warrantable or non-warrantable. Refer to the latest version of the Warranty and Policy Manual online for the latest rear-view mirror warranty coverage information. Use this article to assist in determining warrantable interior and exterior rear-view mirror concerns. Service Information Vehicles with power folding rear-view mirrors may exhibit concerns such as inoperative, folding with clicking sounds, vibrating/shaking in wind/while driving, or does not lock firmly in drive position. This may occur when the exterior rear-view mirrors are manually folded in such as going through a car wash, being bumped in transportation or a parking lot, or only one mirror is folded in. This may be attributed to the power folding mirror being out of synchronization or damage to the mirror mount. Perform the mirror synchronization procedure prior to completing any additional diagnostics. The synchronization procedure may need to be performed more than once to receive the loud popping sound, which is an indication the synchronization procedure has completed. Refer to WSM Section 501-09 Rear View Mirrors – General Procedures – Power Mirrors Synchronization. If the synchronization procedure does not correct the concern, continue with cleaning and inspection before performing additional diagnostics. Diagnostic test results and resynchronization information must be documented if a warrantable defect is found. Concerns that are corrected by the power mirror synchronization should not be submitted under warranty. Loose manual folding exterior rear-view mirrors are most commonly the result of damage to the assembly/mount. Closely inspect the exterior rear-view mirror after cleaning to review for witness marks/impact damage. Loose interior rear-view mirror mounts are most commonly the result of not being seated or the mount/attachment being damaged. Reseating the mirror per the WSM, Section 501-09 Rear View Mirrors may correct this concern. If the windshield has been replaced, damage to the mount can occur from improper removal/installation. Pen test A pen test should be used to determine mirror glass impact damage. Slowly run the tip of a ball point pen inside the crack throughout its entire length. If an impact is present, the pen helps to feel an impression. Cleaning procedure Clean the entire mirror assembly and glass to assist in verification of the customer concern and/or impact damage using water, a cloth, and car wash soap as needed. Do not clean any mirror glass or housing with an ice scraper, razor blade, abrasive pad, harsh chemicals or petroleum based cleaning products, as these may damage the mirror glass and/or housing. Examples Of Non-warrantable And Warrantable Conditions A rear-view mirror assembly can be damaged from abuse or impact and show little or no witness marks on housing. Shiny or flat spots on the housing indicate abuse or impact. Typical non-warrantable damage from abuse or impact Exterior mirror: • Mirror glass missing • Glass with scratches or cracks • Glass loose due to broken pivot or missing jackscrews • Scrapes on housing resulting from impact or abuse • Attachments loose due to impact • Broken mirror motor plate • Glass reattached (glued) after impact • Broken pivot neck/housing Interior mirror: • Interior mirror glass cracked • Broken windshield at mirror mount • Interior mirror detached pivot Typical warrantable conditions • Glass discoloration • Distorted mirror glass reflection • Electrical failure of motors and switches • Wiring harness shorted • Single line glass crack on heated mirror (verified with pen test) • Single line glass stress crack (verified with pen test) NOTE: All mirror components should be serviced at the lowest level available per the Warranty and Policy Manual. Over-repairs when lower-level components are available are subject to review and warranty adjustment. Dirty Mirror Housing (Non-warrantable) (Figure 1) Dirty mirror housings cannot be properly inspected for outside source influence. Mirrors returned without proper cleaning are subject to warranty review and adjustment. Figure 1 Scrapes, Impact, Broken Housing, Loose Attachment (Non-warrantable) (Figure 2) Figure 2 Power Folding Mirror Detent Pin Damage (Non-warrantable) (Figures 3-5) Power-fold trailer tow mirrors are designed to operate the mirror between home to folded position. They are also designed to manually fold forward beyond home position. If the mirror is forcefully pushed beyond the forward fold position, the detent pin in the mirror is damaged and will not stop at home position using the power-fold button. To test this, push the power-fold button. If the mirror unfolds forward past home position (using the power fold button), it is not warrantable. Figure 3 Figure 4 Figure 5 Grain Removed From Plastic Mirror Housing (Non-warrantable) (Figure 6) Physical damage that is often accompanied by power-fold mirror detent pin damage. Figure 6 Glass Loose, Broken Motor (Non-warrantable) (Figures 7-8) Figure 7 Missing mirror glass/backing plate missing (non-warrantable) (Figure 😎 Figure 8 Melted Housing (Non-warrantable) (Figures 9-10) Indicates exposure to excessive heat or chemical contact. Figure 9 Figure 10 Discolored Housing (Non-warrantable) (Figure 11) Stains may have a liquid drip or spray pattern (shown) from contact with harsh liquids. Figure 11 Discolored Glass (Warrantable) (Figure 12) Figure 12 Distorted Mirror Glass Reflection (Warrantable) (Figure 13) Figure 13 Single Line Crack On Heated Mirror (Warrantable) (Figure 14) This crack will occur from thermal stress. Refer to the pen test at the beginning of this article to determine impact damage. Figure 14 Distorted Puddle Lamp Projected Image (Warrantable) (Figure 15) Figure 15 Portion Of Missing Glass (Warrantable) (Figure 16) Adhesive is still present on the mirror backing plate which is securely attached to the motor. Figure 16 Interior Mirror Glass Cracked (Non-warrantable) (Figure 17) Excessive force including improper removal/installation. Figure 17 Broken Windshield (Non-warrantable) (Figure 18) Excessive force including improper removal/installation. Figure 18 Interior Mirror Detached Pivot (Non-warrantable) (Figure 19) Excessive force will detach the press fit pivots. Figure 19 Blocked Light Sensor (Non-warrantable) (Figure 20) Obstruction will cause inoperative automatic high beam. Figure 20 © 2024 Ford Motor Company All rights reserved. NOTE: This information is not intended to replace or supersede any warranty, parts and service policy, workshop manual (WSM) procedures or technical training or wiring diagram information.
  20. Remaining document download links> BATTERY JUNCTION BOX (BJB)-Windshield Wiper Motors-Rain Sensor - Wiring Diagram - 2018 Edge.pdf BATTERY JUNCTION BOX (BJB) - Top View Diagram - 2018 Edge.pdf BATTERY JUNCTION BOX (BJB) - Top View Diagram Legend - 2018 Edge.pdf BATTERY JUNCTION BOX (BJB) - Bottom View Diagram - 2018 Edge.pdf BATTERY JUNCTION BOX (BJB) - Bottom View Diagram Legend - 2018 Edge.pdf BODY CONTROL MODULE (BCM) - Diagram - 2018 Edge.pdf BODY CONTROL MODULE (BCM) - Diagram Legend - 2018 Edge.pdf Good luck!
  21. Additional document download links> WINDSHIELD WIPER MOTOR LH - Ground C111 Location - 2018 Edge.pdf WINDSHIELD WIPER MOTOR RH - Ground G114 Location - 2018 Edge.pdf BATTERY JUNCTION BOX (BJB) - Connector C1035B Details - 2018 Edge.pdf BATTERY JUNCTION BOX (BJB) - Connector C1035A-B-C Location - 2018 Edge.pdf Rain Sensor - Connector C914 Details - 2018 Edge.pdf Rain Sensor - Connector C914 Location - 2018 Edge.pdf
  22. Additional document download links> WINDSHIELD WIPER MOTOR LH - Connector C1655 Details - 2018 Edge.pdf WINDSHIELD WIPER MOTOR LH - Connector C1655 Location - 2018 Edge.pdf WINDSHIELD WIPER MOTOR RH - Connector C1656 Details - 2018 Edge.pdf WINDSHIELD WIPER MOTOR RH - Connector C1656 Location - 2018 Edge.pdf BODY CONTROL MODULE (BCM) - Connector C2280C Details - 2018 Edge.pdf BODY CONTROL MODULE (BCM) - Connector C2280C Location - 2018 Edge.pdf STEERING COLUMN CONTROL MODULE (SCCM) - Connector C226A Details - 2018 Edge.pdf STEERING COLUMN CONTROL MODULE (SCCM) - Connector C226A Location - 2018 Edge.pdf
  23. Welcome to the Forum, phillieeagle ! Having your Edge Sport scanned for Diagnostic Trouble Codes (DTCs) may reveal a cause of the left hand wiper motor symptoms. I did find this Special Service Message (SSM) describing intermittent wiper motor operation due to snow and ice blockage -- clearly not your Edge's issue, though repeated resistance to movement can lead to wiper motor replacement... SSM 48094 2015-2019 Edge Vehicles - Build On Or Before 5-Nov-2018 - Wipers Intermittent Operation Issues In Snow/Ice Conditions Some 2015-2019 Edge vehicles build on or before 5-Nov-2018 may exhibit snow and/or ice accumulation below the wiper blade park position, causing the wipers to have intermittent operational issues. If normal diagnostics do not result in a root cause determination, replace the driver’s side wiper motor with updated service part FT4Z-17508-H, and make sure the customer is advised to keep the cowl area clean of ice and snow. Refer to Workshop Manual (WSM), Section 501-16 and applicable labor operations in Section 11 of the Service Labor Time Standards (SLTS) Manual. Diagnostic and repair procedures are provided in this, and immediately following Forum posts, due to Forum attachment limitations... Document download links> Wipers and Washers - System Operation and Component Description - 2018 Edge Workshop Manual.pdf Wipers and Washers - Diagnosis and Testing - 2018 Edge Workshop Manual.pdf DIAGNOSTIC PINPOINT TEST G - THE WINDSHIELD WIPERS DO NOT PARK AT THE CORRECT POSITION - 2018 Edge Workshop Manual.pdf Windshield Wiper Pivot Arm - Removal and Installation - 2018 Edge Workshop Manual.pdf Windshield Wiper Motor - Wiring Diagram - 2018 Edge.pdf Cowl Panel Grille - Removal and Installation - 2018 Edge Workshop Manual.pdf Cowl Panel - Removal and Installation - 2018 Edge Workshop Manual.pdf Windshield Wiper Motor - Removal and Installation - 2018 Edge Workshop Manual.pdf
