PrinzII
    29
Everything posted by PrinzII
  1. That is correct on both counts. Some vendors use 9006/9012 interchangably.
  2. The ones I got from KC300C are actually pretty good. In fact, they do a nice job of lighting up behind me as I can see the difference with the backup camera.
  3. Candurin: Duly noted, amigo. Vanity Mirrors: http://www.v-leds.com/5K-WHITE-HI-POWER-3-CHIP-p9768538.html Note: Better get your orders for these in quickly. They only have 1000 in stock and two are (finally) coming my way.
  4. This thread is a listing of the LEDs for the 2nd Gen (2011-2013) Edge. Thanks goes to the following for creating the list. Candurin, Kc300c, Cellbine License Plates: hhttp://www.amazon.co...uct/B0047RV8WG/ Front Map Lights: http://www.amazon.co...uct/B0063JGFRY/ Rear Cargo/Dome/Trunk lights: http://www.amazon.co...uct/B0061SHI7I/ Vanity Mirrors: http://www.v-leds.co...P-p9768538.html Reverse LEDs: http://www.v-leds.co...H-p9507296.html Puddle Lamps (DIY): http://www.amazon.co...uct/B004ZVZNPM/ Front Turn Signal Switchback LEDs: http://www.v-leds.co...R-p7114832.html Note: The link is for the 5K Type 2s. They also have 6K Type 2s now. For the 6K Type 1s, I am sorry to tell you that they are currently sold out. Rear Turn Signal: http://www.v-leds.co...ForLanding/true Note: Resistors may be required Side Mirror LED Puddle Lights (Plug & Play): http://www.daytimebr...ights_NL3C.html Vertical LED Running Lights: http://www.daytimebr...ing_lights.html
  5. One member did a shallow mount and modified the box that the 8" came in.
  6. Try this: http://www.jlaudio.com/8w1v2-4-car-audio-w1v2-subwoofer-drivers-92070
  7. JL Audio has a few, but you'd be better off going with the 10" Stealthbox.
  8. I did not change the light housing for my HIDs but did order a 35w 5000K kit from http://www.3bspec.com with Canbus ballast, Warning Canceller, and DRL module due to my Edge having DRLs.
  9. Change the outside mirrors so that the blind spot mirror doesn't take up a ton of space in it. However, I did see something on an RV that caught my interest where there is a convex mirror and a camera to alleviate blind spots.
  10. Case in point, I got the puddle lamps from kc using 5K LEDs to match my HIDs. Even the license plate bulbs match accurately.
  11. Now, I am not just getting wind noise, but also my conversations are periodically cutting out due to the wind noise. Dealer is aware of it. Going to suggest the Dynamat thing to the dealer.
  12. Haz: I will do that when I go in Tuesday to fix my Sync microphone issue.
  13. My mileage is also starting to climb. I am at 18.1 now versus 17.8 a few weeks ago.
  14. 5K License Plate LEDs from kc300c
  15. Shantz: Were the adhesion promoter and flex agent 3M products? I like the front end treatment and cladding. I'd love to do the same to my 2011.
  16. I will echo that sentiment. Got my puddle lights fast and installed easily.
  17. Nice work. Do you use Illustrator at all or are they hand drawn?
  18. Both of mine on my 2008 disintegrated as soon as I pulled down the insulation. It went to the dealer for replacement.
  19. Out of curiosity, how can you shut that off? My dealer said they could not do it since it was hard coded.
  20. Will do. I already did some sizing up and saw two notches at the top that could be pried with a small slotted screwdriver.
  21. Normally, I will use the Eagle One wheel cleaner that also works on tires. Outside of that, I will use a cut all-purpose cleaner.
  22. For those of us who are waiting for these vanity bulbs from V-LEDs, I called them yesterday and was advised they will be coming in today or tomorrow.
