BlackEdition
Everything posted by BlackEdition
After hours of hunting around, I finally found the little bugger! $1 for a connector and a bit of wire isn't bad to fix a major cooling issue. I think cutting the burnt connector and attaching the new one should fix it as unplugging it and plugging it back on made the fans work again, but that only lasted about 3 days. I doubt my entire fan wiring or the controller is compromised. https://aliexpress.com/item/1005002760807461.html This is the only connector that I think needs replacing, I just need someone to confirm before I buy and wait 1-2 weeks to get here? (2013 Ford Edge Sport V6 3.7L, without tow package)
I have the same exact problem as your image. My fan connector got fried and now im driving without the fans working. I looked around for the complete wiring harness for the radiator fans but couldn't find any, so I guess the only way is to cut the wire and replace the plug. Anyone knows the part number for the plug alone (or the entire wiring for the fans)? I couldn't find any: https://www.rockauto.com/en/catalog/ford,2013,edge,3.7l+v6,1504152,electrical-connector,radiator+fan+motor+connector,2556
Front passenger door latch won't close (2013 Ford Edge Sport)
BlackEdition replied to BlackEdition's topic in Exterior & Body
Today I tried everything I could think of, sprayed lots and lots of WD40 and slammed some stuff hoping something would give out, but nothing made a difference. The latch definitely needs to be replaced. Just my luck! I ratchet-strapped the door through the passenger chair and the center console and it seems tight and safe enough for now. The door ajar light is also off so I can go by like that temporarily. Hopefully it doesn't give out on me while im on a drive! Which part do I need? https://parts.ford.com/shop/en/us/body/locks-and-keys/door-latch-door-lock-actuator-motor-right-front-p-bt4z78264a26b?pdp=y https://parts.ford.com/shop/en/us/body/locks-and-keys/door-latch-door-lock-actuator-motor-right-front-p-8t4z78264a26b?pdp=y Mine is a keyless entry (first one) but I don't understand why a mechanical latch would care if I had keyless entry or not? It's a bit steep at around USD$194 MSRP (would definitely be MUCH more expensive at my dealers here in Saudi Arabia), and that's even without labor. I found an aftermarket part that only costs $47 with VAT and free international shipping from the US. Do you think it's a smarter buy or is it not worth the risk, especially because I need to pay a lot for labor? A-Premium Door Lock Actuator Replacement for Ford Edge 2007-2015 Lincoln MKX 2011-2014, Front Right, with Keyless Entry https://amzn.eu/d/ee3dW7B -
Hi! I remember you from some of my topics 10-11 years ago when I first bought my car. Time flies so fast! Glas to see that you're still ok and active around here. Anyway, my issue isn't related to any electronics or sensors. Right now I don't care about making the lights turn off right away vs having to wait 10-20 minutes for them to turn off when the car is off. I just want the freaking door latch to catch to be able to close the door so life can go back to normal, even if temporarily. I don't need to open that door again anytime soon. I can't even drive anywhere in this state unless I tie the door with a rope or something to be able to drive, which is very unsafe. I searched around and read that people suggest spraying WD40 "liberally". I only sprayed a little. Tomorrow I will give it another try, spray the hell out of it, and fiddle with the door handles and locks to hopefully get the latch to catch again. Im guessing something is gunked up or rusted shut because I haven't opened that door much in the last year? I doubt it broke on me out of nowhere for no reason whatsoever. Wish me luck! -
Today when im at home, I opened the front passenger door then suddenly the door latch decided to stop working on me! Here's a video showing the difference between the front right and left door latches: https://www.dropbox.com/scl/fi/1xulsgyj8zpxrumdh5k5r/VID_20240517_181538.mp4?rlkey=kiune4iqpg1e9xu7uwuhhquzg&dl=0 I thought it could be dirt and gunk making it stuck and not latching, but playing around with it and spraying it with WD40 made no difference at all. My battery is also close to dying so I don't want to mess around with the car anymore unless I get some pointers/ideas on how to get the latch to work again because the lights will continue to stay on for about 10-20 minutes since the door won't stay closed. I googled this but found no results with my same issue. All I found were people having an issue with the door sensor saying that the door is open even though it's closed, which never happened to me. I did find a great video showing the entire process for replacing the door latch: Please tell me there's an easy workaround and that I don't need to do all of that in the video? There's no way im going to tackle this by myself, especially not under a 40c weather. Im afraid of going to the dealer and get shocked by some $200-600 just for labor, then the same amount for the parts. This is also a safety issue and I can't drive the car at all, not even to the dealer. Why now? Why today? This is very upsetting and it happened in the worst possible time as im in the process of moving to a new place. My car is in a brand-new shape, less than 50K kilometers and I take good care of it and it was never in an accident. I also always park in a closed garage so there's no rain/moisture getting to the car. Kind of weird breaking on me for no reason at all? I never ever drove/rode/owned a car that had an issue with the door latches. What if this happened while im outside? This is pretty insane and feels like it should get recalled. I never slam my doors and I rarely get passengers on that side. If someone has an idea of getting that door to stay closed without having to revert to some weird and unsafe way like tying a rope to something inside, please let me know. Im going to be a happy man if I can just get it to safely stay closed for now without needing to open it again anytime soon.
Angel eyes size?
BlackEdition replied to Grant Stevenson's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
The oracle ones are too pricey. Almost the price of an entire headlight!- 6 replies
- angel eyes
- 2014 limited
(and 3 more)
Can I use WD-40 as a lubricant instead of grease? I just thought I would get up there and spray the edges and see how it works out but I don't want to mess anything up. Mine opens and closes up perfectly but I noticed that it is slower than what it used to be since I bought the car in 2013/5. My warranty ends in about 2 months so I want to test WD-40 and see what happens (if it works out, then all the issue is with lubricating and not the motor) but if it's the motor then I need to have that replaced before my warranty ends.
- 31 replies
- 2010 Ford Edge
- Vista Roof
What do you guys think about the cooling design on these by XenonDepot.com? would they also require removing the dust covers? http://www.xenondepot.com/9006-LED-headlight-kit-p/9006-led-hl.htm Im more comfortable with this cooling design even if I was required to mod my dust covers, but im not sure if the cooling is as effective as they claim.
Hey guys, I've been eying this new 45W 6000K LED headlight by V-LEDs: http://www.vleds.com/led-headlights/9006-hb4/9006-lmz-2725.html https://www.youtube.com/watch?v=xBnpLt8djI8 I have read other posts in the forum about this new kit, but I didn't really find that much info out there so I thought new thread = more visitors & more discussions (hopefully). I have a 2013 Canadian Edge Sport model, wondering whether this new 9006 kit is all 100% plug & play? Im not that expert when it comes to modifying or changing headlights, and there isn't that much information out there about this new kit and how it performs on our Edges, so im kinda afraid of taking the first hit. Im also not sure which one to get, 3000 or 4500 lumens? I don't want it to be too bright, but I also don't want it to be less brighter than my current HIDs. I couldn't find any comparisions to decide which one suits me better. I also saw this pic on their website saying it's not compatible with headlights that comes with dust covers: Does my Edge come with that dust cover? I seem to recall seeing something like rubber dust covers so im not sure how this is going to work. Like I said before, I want a 100% plug & play kit, no trimming or anything like that otherwise i'll just stick with my current HIDs. Im also not comfortable with having fans to cool my bulbs as I will have to check on them every once in while to make sure they are running solid and not covered in dust or any other particles that might prevent them from working or failing. To anyone who owns this kit on his Edge, please share your thought and experiences as there are a lot of people out there seems to be interested in this product. I would also love to see some pics or videos if possible.
I ditched the ones mentioned in this thread. I bought these instead: http://drivebright.com/home/shop/font-rear-led-bulb-pack-headlight-tail-light-turn-signal-and-reverse-lamps/ These are brighter and much better looking! the build quality isn't that great compared to the PlaZma ones, but they're still awesome.
Sorry to choose my own post as "the best answer", couldn't decide which Wizard's post to choose from. I'll hopefully add a new post in the future for some infos (to sum up this whole thread into one post so new visitors/members can reach the info easily). Once again, I thank you Wizard for your continuous help on this. The LEDs are working pefrectly till this day and I couldn't be happier.
I DID IT! I finally got rid of that annoying/embarrassing hyperflashing! I can finally turn on the DRLs at daytime instead of turning them off all the time to avoid getting those damn hyperflashes. Thank you my dear sir Wizard for your help You can't imagine how happy I am. Im now finally 'completely' happy with all the mods I've done so far, especially Dan's taillights with the LED pack for the fronts & rears, which I was not completely satisfied with because of the hyperflashing that ruined the whole experience for me (I know it wasn't Dan's fault). Once again, thank you Wizard I'll be sure to post some pics and videos soon.
Thank you for the info! I decided to throw away those extension wires, they didn't feel good and a safe idea in the first place. So i'll just be using the load resistor and do it the old fashioned way. Can you help me out with what connects to what? I see 2 yellow and 1 black wire, and the one in the middle seems to have a secondary color:
So the BCM was successfully replaced under warranty, and now everything is back to normal Im gonna go ahead and start tapping into the factory wire using the load resistor, can you help me out with this one Wiz? much appreciated. I want to avoid damaging the BCM again, so just to make sure, would screwing up the resistor connections be another way of damaging the BCM? Im sure my connection was fine, and no metal was touching the copper wires at that time of use. Im also sure that both the LED bulb and the sockets are the normal 3157 (non-CK). I may be wrong about the socket, you can have a look for yourself: And this is how my temporary connection looks like to test it out, not sure if there is something wrong with what I did?
