enigma-2
    303
  1. Perhaps. I talked with someone at syncmyride.com and was led to believe that it was no big deal. (The update only takes 20 minutes, but the dealer needed an hour to an hour and one half to install (quote) from start to finish). Anyway, here's what's in 2.1.4: - Bluetooth auto-connection improvement. - Media player reliability. - Voice Recognition improvements to recognize names entered with all CAPS. - Voice Recognition enhancements that will decrease the chance of calling the wrong person. - Add customer assistance phone number to Help prompts. The update runs itself, just plug it in. Only way it will (should) create a brick is if you were to stop it mid cycle. (I would imagine that's true of any update however).
  2. I have a 2009 MKX and was able to download a copy of 2.1.4 off the web for my car. After downloading you copy it to a 2 gig jump drive and plug it into the USB port on your Edge. Runs from there. Requiring a dealer to do it is simply a sales gimmick from Ford to allow a local dealer to pocket an extra $100 for essentially doing nothing. (I was actually quoted $150 from my local dealer. When pressed, most of the cost was for a mechanic to stand around waiting for the program to install). ...right... Try Google, copies are available for download, but I caution to run your virus checker on the d/l file just to make certain that a knucklehead hasn't sweetened the file on you.
  3. I could be wrong, but I believe HID uses full voltage, just varies the pulse width.
  4. Checked door pillar. It's UG = White Platinum Tri-coat. You had a white chocolate tri-coat listed, but not mine.
  5. Completely agree, probably a generic manual for all Ford products. But it was for 2009 so they must have offered a camera as an option back then. I looked in the copy of the 2009 MKX literature and there was no mention of a camera option. But the head unit in the Ebay listing is identical to my HU. And I believe your right, the yellow plug is for a camera. My guess is they used the same head unit for a different vehicle which did have a camera option (perhaps the Navigator)? In any case, I'm now convinced more than ever that the HU will accept a camera input and all we would need to do is plug in a $20-$30 camera to make it work. Price includes the 19 ft video harness & power harness. Thanks for the Ebay find, exactly the conformation I was looking for.
  6. I was getting this from my 2009 Navigation System, Sync Manual, page 24. ------------------------------------------------ REVERSE CAMERA (IF EQUIPPED) Your vehicle may be equipped with a reverse camera on the tailgate which provides a video image of the area behind the vehicle. When the transmission is in Reverse ®, an image will automatically display on the navigation screen. Once the vehicle is back in Drive (D), the image will continue to display until you are driving over 5 mph (8 km/h). To remove this image from the screen, press any hard button on the navigation system. ------------------------------------------------------------ I assumed from this that it had originally been offered as an option on 2009 models. I had seen the Lockpick before and wrote to them. Response was, the camera works on a 2009 MKX, but not the Lockpick stuff (watch DVD's while driving, etc.). 2009 was only gen 1, and the head unit's software is incompatible. I still want to find out if the 2009 HU has a video port. Anyone with a 09 head unit with hard drive based (has jukebox) Sync Navigation System ever look on the back to see if there's a camera port?
  7. My sensors are flush-mounted into the rear bumper. Where exactly did you mount your surface-mount camera, and what vehicle do you have? I've been thinking about a bracket-mount just above my license plate, (between the license plate lights) simular to the '15 Edge I was looknig at yesterday (only mine would be lower down as the license plate is in the bumper on an 09 MKX. That would put it just above the trailer hitch. I'm concerned that the camera would get covered with dirt and water being so low down).
  8. I was looking at one similar, Amazon, $20. One question I haven't resolved yet is, does the camera connection just plug into the OEM head unit? I have navigation and sync (1st gen). Haven't pulled the HU yet to see if there's a "vid in" jack, but was reading that it was an option on the 09 MKX. This is the camera I was thinking about: http://www.amazon.com/Esky-EC170-06-Waterproof-Backup-0-86X0-65X0-50-inch/dp/B00GSFIJS6/ref=pd_cp_e_2
  9. I agree with your thinking about it being the SecurilLock System. Starter thinks the doors are not locked and having a hissy fit over it. Got to thinking, my 09 MKX has the following procedure used to program the remotes, could try this to see if it works: ------------------------------------------------------------------------------------------------------- Please read and understand the entire procedure before you begin. 1. Insert the first previously programmed coded key into the ignition. 2. Turn the ignition from the 1 (off) position to the 3 (on) position. Keep the ignition in the 3 (on) position for at least three seconds, but no more than 10 seconds. 3. Turn the ignition to the 1 (off) position and remove the first coded key from the ignition. 4. Within 10 seconds of turning the ignition to the 1 (off) position, insert the second previously coded key into the ignition. 5. Turn the ignition from the 1 (off) position to the 3 (on) position. Keep the ignition in the 3 (on) position for at least three seconds, but no more than 10 seconds. 6. Turn the ignition to the 1 (off) position and remove the second previously programmed coded key from the ignition. 7. Within 20 seconds of turning the ignition to the 1 (off) position and removing the previously programmed coded key, insert the new unprogrammed key (new key/valet key) into the ignition. 8. Turn the ignition from the 1 (off) position to the 3 (on) position. Keep the ignition in the 3 (on) position for at least six seconds. 9. Remove the newly programmed coded key from the ignition. If the key has been successfully programmed it will start the vehicle’s engine and will operate the remote entry system (if the new key is an Integrated Keyhead Transmitter). The theft indicator light will illuminate for three seconds and then go out to indicate successful programming. If the key was not successfully programmed, it will not start your vehicle’s engine and/or will not operate the remote entry features. The theft indicator light may flash on and off. Wait 20 seconds and you may repeat Steps 1 through 8. If failure repeats, bring your vehicle to your authorized dealer to have the new key(s) programmed. To program additional new unprogrammed key(s), wait 20 seconds and then repeat this procedure from Step 1.
  10. Installed the mirror harness (from Amazon). Need to be cautious, it was wired backward, the black wire was positive (center contact) and the red was was negative (exterior shell). The mirror has several wires going into it, the black is ground (upper extreme right side - relatively speaking) and the positive when ignition on is the blue (lower extreme left - relatively speaking). Other than that is works perfectly, nice to get rid of the stretched-to-the-max coiled cord.
  11. White Platinum Tri-Coat. Medium Light Stone interior.
  12. See if this helps: http://www.f150forum.com/f2/remote-start-valet-mode-help-52617/ Might take a look here as well: http://www.ehow.com/how_5159008_troubleshoot-ford-remote-starter.html Also remember reading where this happened to someone else. He had to reprogram his remotes. Believe he turned the ignition switch to on, then off, eight times, locks cycled and he hit button on his his entry remote, then turned off the key. Remote start worked afterward. Had something to do with the car not thinking it was locked or something like that. (Refused to start thinking it was vulnerable). Procedure for your car should be in you owners manual.
  13. One quirk I have with my new 09 MKX is the auto dimming mirror. It gets dimmer with rear headlights OK, but it never really goes back to being completely bright during the day (unless I put the car in reverse). I can get it to go completely "bright" (100% non-dimmed) by manually compensating (and it goes completely clear), but afterwords slowly fades to about 30-40% dimmed position. (Also turning on either map light causes it to dim). Is this normal; does everyone else's operate this way, or is mine defective?
  14. Hate to keep beating this dead horse, but thought y'all like an update. OK, following the owners manual and erase all old user codes. Verified that both those I entered are erased. Checked the code inside the fuse box: worked. Checked the code the dealer read when he used the computer: worked. I'm able to program the user codes using BOTH codes!!!!! Both act as factory programed codes. It certainly appears that there are two factory codes (at least on my car). Any other ideas? This is unnerving to say the least.
  15. Five! Based on Akirby's reply, and yours, that kind of makes me a little nervous. Thanks for the information, I'll need to figure out how to erase the old codes. I wonder why it stores four user codes? It would seem to reason that two is sufficient. Allowing the previous owner to retain access to my car is unnerving.
  16. Oh yes, so that's it. Thanks, that's good to know. How would I go about erasing the old codes?
  17. That's what I thought at first, as well. But I do have four separate, distinct entry codes that will open the door. 1. The factory programmed code (printed inside the fuse box): 67*** 2. The code the dealer read from my computer: 49*** 3. My first programmed code (stored at 1/2): 03*** 4. My second programmed code (stored at 3/4): 07*** What I find curious is, why didn't the dealer find the factory number, when he read my car with the laptop? The one that starts with 67? Instead he found the second number. But I do have four numbers that work, just when out to the car and tried them all. Seems to me that if it had been the previous owner's number, I would have erased it when I programmed my new number. They do overwrite, don't they? Or do they accumulate (which could be dangerous). As the dealer read the second number from my computer, I assumed that there are at least two factory codes programmed (at least in my 09 MKX). Could there be some sort of universal code set , like a backdoor, for all Lincoln's or all Ford's, for example?
  18. 1) Passenger door handle: http://www.fordparts.com/Commerce/PartDetail.aspx?n=U0Uulmry6tQQ2AwMtWPGPA%3d%3d&id=295370693&m=2&search=true&year=2009&make=Lincoln&model=MKX 2) The radio knob, try a local junk yard off a dead radio, (there are several on the internet that you could email or check out the listings on Ebay and find a dealer that selling used radios. They may be able to supply you a couple of knobs from a dead radio); or substitute both knobs from one here: http://www.amazon.com/s/?ie=UTF8&node=15684181&keywords=replacement+radio+knob&tag=mh0b-20&hvadid=4960775699&ref=pd_sl_5uk9au1c1k_b 3) Rust: have it fixed on the cheap, or there is a special primer that converts rust to prime (and stops future rusting). When dry, follow with some dupli-Color. (If it's white suede metallic, you will need to use a two-part system to match). http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Dautomotive&field-keywords=rust+primer&rh=n%3A15684181%2Ck%3Arust+primer 4) Moulding is held on by adhesive. I would drop by your local dealer's body shop and ask what they would do. 5) Rechromming would be very expensive and difficult. You could try: http://www.amazon.com/s/ref=nb_sb_ss_i_8_6?url=search-alias%3Dautomotive&field-keywords=chrome+paint&sprefix=chrome%2Cautomotive%2C303&rh=n%3A15684181%2Ck%3Achrome+paint 6) Same as above 7) Glue it back on with rubber cement. http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Dautomotive&field-keywords=rubber+cement&sprefix=chrome%2Cautomotive%2C303&rh=n%3A15684181%2Ck%3Arubber+cement Good luck.
  19. I had the same problem with my old 4-door Mercury Sable. Fixed it by spraying WD-40 into each of the door latch mech. (Turned out it was the rear passenger that was hanging up. Old greese probably. Happened twice while I owned it, so I started spraying WD-40 into the locks once every year.
  20. Just thought I would add a postscript to the question of keyless entry. When I bought my 09 a couple of weeks ago, I had them hook up a computer and read the factory-programmed combination. They did, and when I read the previous replies, checked inside my fuse box and found an entirely different number! Tried both and they both work. Apparently, Ford (Lincoln in my case) programs uses two different combinations. Got to wondering if the number they read in the computer was the previous owner's number, reprogrammed both owner memories with new numbers and rechecked; both factory numbers still work. So now I have four different numbers that will open my MKX.
  21. Wife and I were at Sams Club yesterday, I thought I would browse their automotive section. Seen where they are selling a complete wireless backup monitoring system; consists of a wireless camera, mounts to the car with suction cup , and a wireless monitor, again with suction cup. Whole installation should take about ten minutes. Sells for $99.50. Granted, a suction cup camera will only last for a couple of days before a kid rips it off in a parking lot, but the concept was interesting. I suppose one could mount the camera inside the vehicle, in the rear tailgate window. Would still need to charge the battery occasionally. Be somewhat of a pain. Not entirely practical, but interesting.
  22. I'm new to the forum and I guess I really don't understand to the problem, but... I assume the flashing rate speeds up because the mechanical flasher is not drawing enough current. It seems that the fix should be simple enough, why not just switch out the old flasher unit with an electronic one? An electronic flasher (that is a single relay) will flash your lights at the same rate whether they are incandescent or LED. I assume you all thought of this, so what am I missing?
  23. I read the link, if the pins fall out so easily, why not just wire-tie the cord to the mirror mount for strain relief? Believe I will purchase a mirror power cable, does seem to be exactly was I was looking for.
  24. Alas, neither will work on a Cobra. Guess I'll either resign myself to running an outdated detector, or spending $400 for a new V1. Thanks for the reply.
