enigma-2
    303
  1. Don't know if this is still a factor, years ago when I replaced radios with aftermarket, each radio had to be tweaked to the antenna through the use of an adjustable variable cap (accessed from the rear of the radio usually near the antenna connection). Don't know if the modern HU's can adapt automatically but if not, you could try tuning the radio to the existing antenna by adjusting this cap.
  2. I had a Mercury Sable that had this problem, grease dries out. I fixed it by spraying WD40 into the lock. The WD cuts through the old grease and allows the lock mechanism to function properly. Try spraying some into the lock (open the door and spray from the latch side) and then open and close your door a few times to work the WD40 into the lock. Used to have to do this about once every two or three years to keep it from sticking.
  3. Try resetting the RSS system by putting the transmission in reverse and pressing "reset" to turn system back on (or off).
  4. I've tried several different cell phone holders and finally ended up with this one. http://www.amazon.com/gp/product/B00JNJPS4W/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 It clips into the instrument panel vent louvers. In my case, it allows me to position my Galaxy 5 directly under my Escort Passport Max. (This radar detector connects to my cell phone through bluetooth to locate speed traps as much as a 10 miles out; before the radar detector actually can detect a radar signal. Also displays a real time map to show all of the latest police sightings on the map and shows in feet the distance to the hidden speed trap; starting about a mile out. Does this by connecting all Passport detectors together via the cloud. When anyone detector detects a radar signal all of the others are informed on their connected cell phone). One of the biggest problems with the other vent holders I've used is they hold the cell phone OK, but the vent louvers tilt with ever bump and the cell tilts as well. This holder is designed differently. I found that if you use the lower vent louver to attach to and use the bottom frame of the vent for support, the holder is rock-solid and doesn't move at all. Simple to install and remove. You can easily swivel it from vertical to horizontal and change the angle to suit. It's possible to attach the phone with one hand, easier if you use two. Price is $16 (w/free 2-day shipping if you have Amazon Prime).
  5. 56 Ford Vicky. Red and white. Used to play bumper tag with it. Burned so much oil I bought in bulk (recycled oil). Ended up painting it by hand (with a brush no less). Brakes failed and ran into another car stopped for alight. Panicked, smashed on the emergency brake and hit the horn. Impact was about 10 mph so not much damage. "Those were the days my friend...".
  6. Well that seems to be working. I don't think I've missed a single pothole in the last week!
  7. Well that seems to be working. I don't think I've missed a single pothole in the last week!
  8. Try putting the head unit into the diagnosis mode and see if it finds a camera. If it does, it should set the bit to turn it on. After it reboots, you should have a backup camera if everything is working properly.
  9. I had this happen to me with my last car. Read that it was old grease in the latch that was gumming up the switch. What I ended up doing was to spray WD40 into the latch (just opened the door and sprayed it into the latch). Opened and closed the door vigorously a couple of times and the lights went out. Had to do this every couple of years or so. Give it a shot. doesn't cost anything and no harm done if it doesn't work.
  10. My MKX came with 245/60R18's and the former owner put on 245/50R20. What real value does the 20 inch tires have over the 18's? Is it just for looks? Same height and width, slightly less revs/mile, not enough to justify the cost, imo.
  11. Was in showroom other day while having MKX serviced. Looked at the new Edge and backup camera was mounted just above license plate (between license lights). If you don't have navigation, doubt you could use HU to display. Instead of a hidden display, how about changing your backup mirror to one with video. http://www.ebay.com/itm/7-LCD-Screen-Car-Rear-View-Backup-Mirror-Monitor-Wireless-Reverse-Camera-Kit/151359137746?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D29310%26meid%3D06adf646f7384c8c93a02f3bb8c52c28%26pid%3D100005%26rk%3D4%26rkt%3D6%26mehot%3Dpp%26sd%3D171576394380&rt=nc#ht_6176wt_1128 Or would something more like this work better? http://www.ebay.com/itm/Car-Rear-View-System-Wireless-Backup-Camera-4-3-TFT-LCD-Monitor-/141586942168?pt=LH_DefaultDomain_0&hash=item20f73d48d8&vxp=mtr#ht_7433wt_1306
  12. Thanks Wizzard. Looked up the original post, and found another one that detailed bending on the ground using a pipe. I may consider this, still thinking about going OEM. Seems that I remember reading somewhere that the 2010 and 2009 were the same. Wondering if you would mind slapping a tape measure across your 2013 and see how the posts compare with mine. My headrest posts are about 3/8" in diameter and spaced about 5-7/8" inch center-to-center. (Holding a tape measure in front and eyeballing)
  13. When I bought my mkx, I got the PremiumCare (covers over 1000 items) and my car had 84k on it. Did you check the Ford website? http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/ESPWizardStep1
  14. Is it possible that the memory seat buttons just are not programmed? Try setting the drivers seat to an awkward position, say all the way down. Then program the memory seat button number one. Press the SET control on the driver’s door panel. Within 5 five seconds, press the lock or unlock control on the Integrated keyhead Transmitter and then press the 1 or 2 control on the driver’s door panel which you would like to associate with the seat and Driver 1 or Driver 2 positions. Then move the seat to a different position, say mid heght and press the memory seat button to see if it takes you back to full down.
  15. Buttons connect to pins 16 (botton 1) & 17 (button 2) of the driver seat module. The module is powered from fuse F12 of the fuse box and fuse F60 in the battery junction box. Power seats come off F12 so I doubt that's the problem. Drivers seat module is located under the drivers seat.
  16. Look at the service manual, it's impossible to ell. The Guides are different (not just different size) between the two and both insert into a steel channel, more like a short section of steel pipe, which appears to be welded to the top of the seat frame. My guess is the steel portion is larger on the F150 and the F150 guides will not fit into the Edge channels. Only way to be certain is to buy a F150 guide and test it.
  17. Was it simular to the setup Ford uses to connect to the car? Did your locksmith refer to anything special in his advertising?
  18. Anyone know if a 2014 MKX tilting headrest will fit a 09 MKX? (Wife hates the angle of the stock headrest).
  19. TireRack http://www.tirerack.com/tires/SelectTireSize.jsp?autoMake=Ford&autoModel=Edge+SEL&autoYear=2007&autoModClar=AWD&brand=Yokohama didn't recommend that particular tire for your car (either FWD or AWD). They sell it, but wasn't recommended for the 07 Edge SEL AWD or FWD. For Yokohama they spec'd the Geolandar H/T G056 @$131 ea, the Parada Spec-X @ $172 ea and the AVID ENVigor (H- or V-Speed Rated) @ $147 ea. http://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=AVID+ENVigor+%28H-+or+V-Speed+Rated%29&partnum=46HR8ENV&vehicleSearch=true&fromCompare1=yes&autoMake=Ford&autoYear=2007&autoModel=Edge%20SEL&autoModClar=FWD The surveys don't rate this tire very high, scoring low in "would you buy again, light snow, deep snow and ice. http://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=AVID+ENVigor+%28H-+or+V-Speed+Rated%29&partnum=46HR8ENV&vehicleSearch=true&fromCompare1=yes&autoMake=Ford&autoYear=2007&autoModel=Edge%20SEL&autoModClar=FWD Click on "surveys" and "reviews" for actual user reporting. A better tire and less money (at least at TireRack) would be the Bridgestone Dueler H/L 422 Ecopia @ $128 ea. http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Dueler+H%2FL+422+Ecopia&partnum=46TR8HL422&vehicleSearch=true&fromCompare1=yes&autoMake=Ford&autoYear=2007&autoModel=Edge%20SEL&autoModClar=FWD This are the tires I'm running on my 09 MKX AWD and find them to be very smooth & quiet, and have good traction on wet roads and in snow. Not so much on ice. For the price, they are a better buy IMO.
  20. Air fow is through the core and then as directed by blend door actuator(s). Actuators are controlled by HVAC module. Service manual leans towards failing actuator (sticking or bent linkage). If it was the heater core, seems as if you would get little or no airflow through any of the outlets.
  21. If you can get it run, run a diagnostic and post what codes it's showing.
  22. It does sound ridiculous, but it really could be around $300 if they are quoting the new laser-cut keys! My local dealer can't cut them and has to call in a local locksmith (only one guy in the area that has this new laser key cutter. Dealer told me they could not justify the cost of the machine vs the relative few times they would be able to use it. (Forget what he said they were quoted, but it was in the thousands). He showed me one of the new keys and they are completely different; actually need to be cut precisely with a laser. Think he said it was starting on the 2015 model (forget which model it's starting with), but eventually all models in lineup will use new type keys. Think he said they charged they guy over 300 for one key.
  23. It's just five numbers, no letters. Like akirby said, enter a little slower. It the code doesn't take, wait a few seconds before attempting it a second time. After you master this, consider entering your own personal code. Enter the factory code and after you get a confirmation, press the the 1-2 button on the keypad. Then enter your personal entry code. Don't use your home address, telephone number or anything common to yourself. One of the neighbor kids can guess this and, once in the car gain access to the factory code in the fuse panel. (It happened to someone else here in this forum). You must enter each digit within 5 seconds of each other or it will reset. To enter a personal code and activate the memory recall feature (seats, mirrors adjust) after you enter your new personal code, press the 1-2 button for driver number one or 3-4 button for driver number two. If you programmed the entry code properly, the doors will lock and unlock to confirm.
