                Posts259
                Days Won3
Everything posted by Brucifer
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
	  2007 SEL Key Programming IssueBrucifer replied to Brucifer's topic in Alarms, Keyless Entry, Locks & Remote Start One Factory, one clone.
	  2007 SEL Key Programming IssueBrucifer replied to Brucifer's topic in Alarms, Keyless Entry, Locks & Remote Start UPDATE: Bought three switchblade keys off EBay and got all three to work with home programming.
	  Changing 2019 Edge's weak single horn to dual hornBrucifer replied to 9mmbullitt's topic in Accessories & Modifications $5 in You-Pull-It Caddy horns, a relay and some wiring: Mounted inside the cover of the driver side wheel well. Lincolns are another good source for horns. Just a two horn set-up. I think stock is 4 horns with different tones. I went with a high and low that sounded good.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Changed the oil. Mobile 1. Added this stuff: https://www.amazon.com/gp/product/B07H9K62X3/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Can't say I paid attention before, but I think it sounded a tad quieter after start up. Could be the money filter. Why? https://www.youtube.com/watch?v=m8ZKMCfAue4 EDIT ADD: Also got three switchblade keys for it off of EBay. All of them programmed in on the first try with no problems. https://www.ebay.com/itm/FLIP-KEY-REMOTE-FOR-FORD-F150-F250-EDGE-40BIT-TRANSPONDER-CHIP-KEYLESS-ENTRY/130687018678?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Any suggestions as to slightly over powered lift gate arms? Don't want to break my jaw when I unsnap the gate, but something that definitely has some oomph.
	As long as everything is being replaced, it would be a good idea to have the brain box checked. Bad box can make for bad coils and bad coils can make for a bad box. https://circuitboardmedics.com/2007-2010-ford-edge-pcm-ecm-repair/
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications All four rotors and brakes. For those playing at home: Fronts: https://www.autozone.com/brakes-and-traction-control/brake-rotor/duralast-gold-brake-rotor/539222_195255_2708 https://www.autozone.com/brakes-and-traction-control/brake-pads/duralast-gold-brake-pads/939349_232493_3773 Same version for rears. Front pad box had two extra little clips. Not sure where they went. Didn't use them. Started at noon and finished at 6. Re-learning curves are a bitch. Installed the rears and went around the block. Could feel a grinding sensation. Installed the front and had same grinding feel in the front. Seemed to settle down a tad by the time I got home. Will make a pizza run tonight, so I'm hoping it's a wearing in thing. No other horrendous noises. Parking brake is a little low. For added fun, after I recessed the calipers, I put everything back in place and shot everything with black 2000 degree paint. I had already done the hats on the rotors (taped at the bottom of the hat and used the factory plastic as a blocking agent). Old hats were all faded and rusty. Calipers look good for now. Time will tell.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Sorry for the delay, but I hate the site's new layout and rarely come here any more. One looks like for an '08 and one for a '12: https://parts.lakelandford.com/p/Ford__/Housing-TRANSMISSION-mount/52086753/8T4Z6068B.html https://parts.lakelandford.com/p/Ford__Edge/Housing-Torque-arm-TRANSMISSION-mount/51620415/DT4Z6068A.html Best thing to do is match up what you got with what's in the pic.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Passenger airbag replaced.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Some time ago, but finally got the pics off my phone. Stopped to get breakfast. When I came out, I noticed all sorts of rust and bubbling along the rear fender well. I don't keep the cleanest car in the world, but when the hell did this happen??? That's when I paid a little more attention to my surroundings: I wonder if the other '07 noticed what they did (I'm in the back).
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Maybe. I think it looks kinda like a torch. Has two lines coming off it. It has an electrical plug in that comes in from the main three brain box plugs. To the left of the brake fluid reservoir. In most Edge engine bay pics, it is right below the two bolts on the windshield cowling. Right below the right hand bolt: At least I have a name to look up in the factory book. One of the locking clips broke off and I want to try and replace it Thursday when I'm by the dealer.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Finished the valve cover gasket for the second time. First time it got pinched. I think I raked it across the engine support bracket by the firewall. Used a mirror this time to confirm blue gasket across the length. One of the injector clips had broken off, so I goobed some black gasket goo in it's place and stuck it back on. If it does go wonky again, I can at least see it on the passenger side of the intake. Some burning, but I think that was from all the oil that poured out after the pinch. What's the black thing mounted on a post behind the resonator? Has hard vacuum lines coming off it. If anyone needs to do the radiator side valve cover gasket replacement on a '07-'08, let me know. I have extras.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Got the 4 oil seal rings out (slip joint pliers), but don't have a good way of replacing them. Luckily, there is a shop within walking distance and I'll see if they will be willing to press them into place so I don't bugger the whole thing up. Then it will just be a matter of a couple of dabs of goo, and bolting it all back together. Not sure how the wiring is going to hold up over time when I was busting the VC bolt plastic cap-holder things left and right. I'll be happy with no leaks and all the electrical plugs in place at this point.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Found and going with this:
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Firewall side. Was smoking from oil leaking out from the corner of the cover onto the exhaust. Mechanic put his mirror back there to confirm. Old gasket was pretty stiff in parts, pliable in others. Changing out the plugs because I'm around 30k on them and I don't feel like taking everything apart ever again. Got the Fel-Pro set. Gasket is in the cover groove. I also got a bunch of smaller gaskets that go around the bolts. How do I change these out? Don't see a way of slipping the new ones over the thin metal disks even if I cut the old ones off. I don't have the tool to set the spark plug seals, but that's what large sockets are for. ?
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Doing the right side valve cover gasket.
	  2007 SEL Key Programming IssueBrucifer replied to Brucifer's topic in Alarms, Keyless Entry, Locks & Remote Start Tried all three flavors and nothing seems to work. The 8-count method is the only one that seems to give me a positive reaction as for programing. Like you said, it may be the Chinesium in the key finally giving out (or because I threw the fob recently). Not sure how many more keys I can add to the system before wiping and starting all over. Have some running around tomorrow in the area of my local, full-service locksmith tomorrow, so maybe I'll get a quote. If I have to buy a set of factory keys, I'm going to try and make them all switchblades. If the groves and the frequencies are the same, I can't see why not. I think my wife has a spare key with her, so I have at least two fully working ones, but I might be running out of options.
	  2007 SEL Key Programming IssueBrucifer replied to Brucifer's topic in Alarms, Keyless Entry, Locks & Remote Start Thanks. Printed a hard copy.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Stopped by the dealership today and they ordered my passenger side airbag. 1-2 weeks out for that, then half a day install.
	I can't find anything on this new infernal site, so I have to start a new thread. Have a working 'switchblade' key that I use all the time. Range started fading on it, so I replaced the battery. Didn't remote at all now, but will start the car. Got the original key out to reprogram everything. Close door. Open door. Unlock. Off/Run 8 times in 8 seconds leaving in run. Lock acknowledge programing mode. Every time I hit any button on the original key, the horn honks. Switchblade doesn't take the programing. I think I remember that there were two programing routines: one to make the car run, and one to program fobs. I think I'm doing the fob one, but even Google is failing me.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Got the brake lines flushed.
	  07 Ford Edge Transmission TSS OSS SensorBrucifer replied to Buffmont's topic in Audio, Backup, Navigation & SYNC Just checked my paperwork. Sensor parts: $140. Remove and replace parts: $525. Had similar issues as to shifting: delay/miss shift. Replaced original plugs and coils at 125k. Had brainbox checked out. Eventually had whole tranny replaced. Better, but issues still remain. Search through my posts as for detailed threads. Early and can't think. YMMV.
	  What have you done to/with your Edge/MKX today?Brucifer replied to WWWPerfA_ZN0W's topic in Accessories & Modifications Dealer oil change (163k) and they swapped out the serpentine belt.
	I wired in Caddy horns.
