lildisco
    36
Everything posted by lildisco
  1. I was able to take part of the fender liner off & installed a 2015-2018 OEM Ford edge horn. Plug & play, less than 10 minutes on our 2020 SEL AWD.
  2. They should have with the volume button. I'd read the owners manual & if that doesn't work, I'd make a trip to the dealership.
  3. Thanks. I guess it is serviceable when you split the trans open, lol. Here's MacT talking about the ULV fluids: https://youtu.be/kJQW6wXS0qg?si=e4Hbwa7tYkCXaygT
  4. To my knowledge, there's no filter in these transmissions, so any wear from the transmission just sits in the coolant & cycled through everything. When I do another 3x drain & fill I'll probably switch to Valvoline. Probably by that time MacT will have changed his 2019 fluid a couple of times & report on the results.
  5. I also swapped the PTU Fluid to Redline Lightweight Shockproof (AKA Smurf Blood, because it's blue). After ~8,000 miles, there's way less gunk in it, compared to OEM, but with ~8,000 miles, that's nothing on new fluid, but I wanted to make sure that I got as much of the OEM fluid out of there. The 1st pic is the 1st drain with the OEM fluid & this is the most recent drain with Redline Lightweight Shockproof
  6. This is from the 2nd drain & fill, slightly more red, but not a lot. It is my understanding that the OEM ULV fluid turns dark pretty quick. Someone suggested Valvoline makes a ULV fluid that stays red much longer than the OEM.
  7. Here's the 1st drain & fill I did on our 2020 SEL a few weeks ago just under 27,000.
  8. Ziebart traps in moisture & rots metal from the inside out. Use a breathable undercoating like fluid film, unless you don't plan on keeping your vehicle for an extended period of time.
  9. Also decided to do a transmission Drain & fill x3, touch up my undercoating with Fluid Film & swap over to my winter rubber on our 2020 SEL AWD. Spring me screwed fall me & didn't clean the winter wheels when the weather was nicer & warmer. So that took some extra time & nice hot bucket of water. Besides touching up the door hinges & the bottom of the doors & hatch, I should be ready for winter. The 1st drain & fill got about 4.2 qts out & the other 2 got 3.5 qts out. Motorcraft Ulv fluid was $3/qt cheaper than Valvoline equivalent. Fluid was quite dark & a tiny hint of red in it. On the 3rd drain, there was more red in it. Currently ~26,000, but I did a lot of hauling with a small utility trailer & ztr this year & wanted to be extra cautious. A friend of mine who owns a transmission shop said that I should be fine till next year, but was shocked at how dark the fluid was. It was getting late & I was tired & forgot to snap a Pic of the 3rd drain, but it was more red than the first 2.
  10. I have them on my 2020 SEL AWD. I ran them above my curt hitch & conceal it behind the bumper cover when not in use. The I use my portable air compressor which I keep in the hatch area & inflate them. Makes a nice difference when traveling with a lot of cargo in the back.
  11. Roughly time for an oil change, so I decided to do that & drain & refill the PTU. The PTU had about 8,000 miles on it since I drained the OEM fluid & replaced it with Redline Lightweight Shockproof 75W140. It had very little gunk on it compared to last time.
  12. My 2020 SEL didn't come with the insulation or engine cover. Ordered both & installed in under 10 minutes. The hood insulation seems to be worth it, especially since we live in the rust belt.
  13. I think our issue was the oil pressure sensor just above the oil filter. Has telflon tape on it I think. Took my mechanic 2 visits to find it. Since he replaced it, the garage doesn't smell like oil & no puddles under it. Going over 4 months since he replaced it & 0 oil on the pan or surrounding areas
  14. I thought that purge valve is under the hood on the drivers side of the engine. Is there a canister purge valve in a different location? Our 2016 2.0L purge valve was on the driver's side of the engine. Was ~$150 part.
  15. Usually the purge valve, but I believe that there's a vent somewhere in the gas tank full tube. I'm not 100% sure.
  16. Did you use OEM? I had an after market one that lasted a few months before needing replaced. 1st one was after market, 2nd was OEM. 3+ months on the OEM.
  17. Oil Change today. Was nearly at 6,000 miles since I changed it last. OLM said that it was 57%. I did have 2 highway trips so maybe that's why it thought it could have gone more. I usually change it around 50% & that's right around 5,000 miles.
  18. I get the urge every other yearish. This year the weather was cool enough where I wouldn't drip with sweat doing it, so that was my reasoning this year, lol.
  19. It's so tiny compared to the other trailer I hauled the same mower with. Rides nice (once loaded) & my air bag helper springs keep the rear from sagging too much.
  20. Greased the trailer axle bearings yesterday. Drivers side was a dark purple color & the passenger side was more of a dark red ish color. Thankfully, they're Dexter E-Z Lube axles & we're quite easy to put new grease in. I'll probably lube them 1 more time this year & then I'll do it annually after that to make sure that old grease is out. Guess we'll see how the summer goes.
  21. Oh & mandatory trailer dolly as I'm on a slight incline from my driveway. Much easier
